My t.v. will turn on but after 2 to 3 min it cuts back off. what is wrong.
1989 ford f-150 start but stalls out
Injector require 40 PSI on a Ford. Your Fuel Pump is BAD
Apr 08, 2013 | 1989 Ford F 150
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
I can cut for about 4 min. then Cup Error
look at your duty cycle 40 % duty cycle is 4 min 10 min sraight is minimum 100%, but good machines weld for 3 or 4 shifts till they get turned off
my 2 cents
Feb 25, 2010 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Compressor start for a few second and cut off and start again. whats wrong . berverage-air freezzer single door model no. ef24-1as
dirty condencer coils bad fan motor or compressor start relay on the side of compressor or turned off then back on without waiting 5 min.
Dec 09, 2009 | Beverage-Air Freezers
I have a 2002 Pontiac Grand Am GT and almost everytime I come to a stop and have to sit at light or stop sign, it cuts off. It will start right back once i put it in Park and cut it back on. Been going on...
You need a new repair shop. This is fixable when you say it happens this much. Intake leak. Bad IAC quickly come to mind. Go to IATN.com to locate a competent Tech.
Dec 08, 2009 | 2002 Pontiac Grand Am
Thermostat turns unit one every 5 min
check your filter if it is dirty it will not allow enough air flow and cause the heat limit stat in the unit to trip causing unit to cut off when it resets it will come back on.
Dec 23, 2008 | Honeywell Focus 6300B 5-2 Days...
Dryer is cutting out after about 2 mins will let you turn it back
you have to check the heater & motor, probably earth leakage.
Dec 02, 2008 | Dryers
Fan assisted oven keeps going off ?
there is an overheat stat and this is cutting the oven off
things to check are.
is casing fan running ok? (this is the tangential fan inside the casing at the back and not the fan inside the fan oven)
this second fan is turned on by a fan stat. maybe this is faulty
is there plenty of ventilation?
is oven in fact overheating?
Oct 18, 2008 | Ovens
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
