Question about Kenmore Washing Machines
Cloth are still very wet after wash (it used to be very dry and it started happening since last week)
  • gospelstuff Nov 09, 2014
    BAD BELT OR CLUTCH
  • 714 Answers
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Feb 07, 2010
Clothes are still wet after last spin cylce
Most washing machines do not dry the clothes completely. Make sure that your clothes are evenly spaced & the weight is balanced to get the best spin speed. When the cycle is complete, you will need to put the clothes into a dryer or hang them up to get them completely dry.
Aug 30, 2015 | Washing Machines
Leaves clothes too wet after spinning
you might need to set the dryer dial to more dry and not less dry that helps the clothes to dry faster
Apr 28, 2015 | Washing Machines
I own a Kenmore washer Model 110.22722100. The last couple of weeks, it leaves the clothes wet. It drains like it is supposed to and spins. What is causing this to happen?
Here is the part you will need.
Nov 28, 2010 | Kenmore Washing Machines
1 week ago the dry was extremely hot and now this week the dryer is cold and the clothes are wet.
Last week your cycling thermostat went bad. This week you thermal fuse went out. This is how it happened.
You dryer cycles on a thermostat. When it goes out the dryer then cycles on the (high limit) thermal fuse. When it goes out. The dryer stops heating. You will find both after you remove the back of the dryer. They are easy to replace. There are two different thermal fuses but if you order the parts using the model number you will have no problem. These two parts are sold in a kit.
Please rate this solution.
Sep 01, 2009 | Kenmore Dryers
Whirlpool LSR7010PQ2 can't spin dry, clothes still wet
If it was spinning slow before the total failure It would be your clutch ,Check your lid switch.
Apr 24, 2009 | Washing Machines
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
My Washer does not spin or agitate when washing, but it spins when drying on cycle...
Hi Mate,
Check the controller, is it digital or analogue ( pushbutton or control knob that turns ) Sounds like part of the switching cycle has burnt out replacement of controler may be the answer
Stoker
May 11, 2008 | Frigidaire GLWS1233A Top Load Washer
Top load does not spin dry the clothes
Transmission or solenoid that should pick and put transmission into spin. I bet it's a kenmore or similar.
Mar 08, 2008 | Washing Machines
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
183 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
