Question about Cardo S-800 Bluetooth Headset Wireless Headset
How do I put it in discover mode?
How do I put my cardio s-800 headset in discover mode?
    President:
  • 1,738 Answers
How to Pair Cardo S-800
1.Turn on your phone and turn ON its Bluetooth function.
2.Make sure the headset is turned OFF, then press and hold the Power Button for approximately 8 seconds until the LED status indicator begins alternating blue and red, indicating that the headset is in Pairing Mode.
3.Set the phone to search for Bluetooth devices by following the instructions in the phone’s user guide. This is usually found in the phone’s Bluetooth menu and may be referred to as “discover” or “add” a device. (Settings > Connectivity > Bluetooth - turn ON - > Discover Devices)
4.After a few seconds, the phone will list the “Cardo S-800” as a discovered device. Select it from the list and press “oK” or “yes”.
5.When prompted, enter the passkey “0000” (4 zeros) and press “oK” to complete the pairing
6. When the pairing pairing is successful the headset’s LED status indicator will begin flashing.
You should now be able to make and receive calls using your headset. To initially connect the headset to your phone, you may need to tap the CTRL Button once on the headset. iMPortAnt: if pairing is not completed within 2 minutes while the Pairing Mode is activated, the headset will return to Standby mode, flashing blue once every three seconds and you must start the Pairing process again from Step 2 above.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
Posted on Feb 07, 2010
How do u bluetooth in descovery mode
The Bluetooth headset in discovery mode is looking to connect to another Bluetooth device, be it a mobile phone or computer. Before you can use your headset, you will need to pair the two devices (or make them discover each other) so the headset has something to communicate through. This headset user guide has the pairing instructions on pages 3-5.
http://www.headsetsdirect.com/pdf/explorer230_ug_en.pdf
Good luck from Headsets Direct - 800-914-7996.
Aug 14, 2011 | Plantronics Explorer 240 Bluetooth Headset
Tip
How to put most Bluetooth headsets into Pairing Mode?
There are two main ways to put your Bluetooth Headset into Pairing/Discovery mode:
1. For devices that have a Power Button
Start with the headset in the OFF state, then hold the power/action button until it goes into pairing mode (about 3-5 seconds). When in pairing mode, the light should be flashing red and blue or have a steady blue light, in most cases.
Then you can discover it with your phone or PC.
2. For device that have an On/Off SWITCH
Start with the headset in the OFF state, then hold the call/action button while you turn the headset ON. The headset should now flashing red and blue or have a steady blue light, in most cases.
If you forgot the pairing code, refer here:
http://www.fixya.com/support/r5008953-pin_codes_most_bluetooth_headsets
If you need a copy of your manual, refer here:
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
on Jun 02, 2010 | Radio Communications
How do I put the unit in discover mode
Putting the Plantronics Voyager 510 into pairing mode:
With headset on, press and hold the call button and the volume up simultaneously until the headset begins to flash red and blue.
Select the Plantronics 510 headset in your phone when prompted and enter 0000 (4 zeros) as the PIN/passcode if prompted. When paired, the Voyager 510 headset should now have a continuous blinking blue light. Here is a link below for the step by step pairing instructions.
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
Aug 12, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How to connect bluetooth headset to nokia 2700 classic?
put the headset in detectable mode, put the phone in pairing mode and the two should discover each other and should just connect.
Jul 01, 2011 | Nokia Bluetooth Headset Headset
Phone cannot find headset
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone.
Mar 11, 2010 | Samsung Bluetooth?® WEP200 Headset...
How do you connect samsung bluetooth headset wep460 to a vodaphone 541
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Dec 25, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
How to conect Motorola H500 Bluetooth Headset to Iphone
Nov 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Connect ge bluetooth to blackberry pearl
Jun 24, 2009 | GE Bluetooth In-ear Headset Wireless...
Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Jun 02, 2009 | Motorola Mobility HS850 Consumer Headset
Discovering a Motorola H721 headset on my Iphone
open the boom flip. Press and hold both volume buttons and the call button for more than 10 seconds. The indicator light flashes 3 times and then becomes steady lit. The headset is now in pairing mode.
Nov 26, 2008 | Motorola Cell Phones
Cardo S-800 Bluetooth Headset Wireless Headset Logo
1,096 people viewed this question
Top Cardo Radio Communications Experts
Eric Sutherland
richie46
Tom Chichester
Are you a Cardo Radio Communication Expert? Answer questions, earn points and help others
