Question about Microwave Ovens
My icemaker stopped working on my lg refrigerator. I don't know where to find the model #, it's 2 yrs old.
  • melissagonza Feb 07, 2010
    Thanks for the fast response. More info than we've been able to gather on our own.
  • 311 Answers
If you have water through the door the first thing to check is water pressure. If the water is just dribbling out of the door or is coming out very slowly then the problem is with your saddle valve. It will be located in the basement or crawl space usually just trace your water line from the back of the ref and see where it goes. It is the valve that actually taps into your water pipe to feed the water to the ref. You can shut off the water to the house and open the valve up and clean it out with a pipe cleaner or piece of wire or just replace it with a new valve they are only about 10 bucks.
The second thing you would have to check if your water pressure is good would be the inlet valve. You can usually take an ohm meter to the valve (located in the back of the ref behind the access panel) to check the solenoid for continuity.You will want to check the solenoid that feeds the ice makers water line. You could also remove the water line that feeds the ice maker from the inlet valve itself and blow into it this will let you know the line is clear and your fill tube (tube in freezer that feeds the icemaker) is not frozen.
If the inlet valve checks ok, then you will most likely have a bad ice maker. These will often go bad on LG's especially if it is the flex tray style.
Hope this helps. Good luck _MJ_
Posted on Feb 07, 2010
Microwave oven just quit working....is there an internal fuse that i can replace?
Yes, but chances are it is not the fuse. I just fixed an LG with the same problem by replacing a thermostat, that went bad. On this model the power goes through a filter and then 2 thermostats before it will power up the board. If you are not familiar with electronics and the unit is over 3 yrs old I would just buy a new one. my part was $4 but to have a tech replace it will probably cost you $100.
Feb 27, 2010 | Kenmore Microwave Ovens
LG RefrigeratorModel LFX25960ST - icemaker has been replaced once
Most ice maker heads cost less than $49 to replace if you get it at a wholesaler. The water quality going to it will effect how long it will last, Reverse Osmosis treated is the best, filters will help some but are not a cure. Your budget is the determining factor in this equation.
Nov 21, 2009 | Microwave Ovens
Hotpoint 1 and one-half yrs old stopped working
Ck and make sure the circuit breaker on the power panel on the house hasn't tripped.. If your microwave is within 6' of the kitchen sink, ck for a tripped GFCI controlling the power the microwave is plugged into. Good Luck, Ned
Sep 15, 2009 | Microwave Ovens
Microwave is not working
One of the door switches needs to be replace.
Oct 30, 2008 | GE JVM1440 Microwave Oven
Lg LMV1630st stainless steel microwave oven
I'm confused. If it's 6 weeks old, you can get it repaired free.
If it's 1-1/2 years old, the manufacturer will cover the part cost of the magnetron (assuming that's what's wrong) and you will have to pay for labor and any other needed parts.
Also, the subject line mentions a model LMV1630ST while your message body mentions model LMV1680BB.
For Goldstar / LG / customer service, help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Chances are your problem is a bad magnetron, but it may be another high voltage part.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Microwave Ovens
Make sure the door is aligned and closes safety switches.
May 02, 2008 | LG LMV1630ST Microwave Oven
LG MODEL M C 804 A - MADE IN KOREA
Most microwaves have a fuse inside. Disconnect power and remove the outer case. If you follow the power cord, it should be connected to a fuse.
Dec 21, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
