Question about Air Tools & Compressors
MY PASSLODE FINISH NAILER WILL NOT FIRE, EVEN WHEN IT HAS A FULLY CHARGED BATTERY AND FUEL CELL. WHAT COULD BE THE PROBLEM ?
  • David Ford
    David Ford May 11, 2010
    could be bent probe not allowing full travel on the cylinder, could be a defective switch, what is the exact model number and I will give you some troubleshooting hints for the tool, there are different methods to try this.
  • 21 Answers
Check your fuel cell. on the bottum there is a date. if it is out dated that could could be it
Posted on Feb 14, 2010
Bostitch GFN1564K cordless nailer brand new wont fire.
take it back to the supplier for a replacement or warranty fix
however as it is electric there may be a safety switch that you have to engage to make it work as it would go off when ever and spray nails and staples every where.
Jun 27, 2015 | Stanley Bostitch Gfn1564k 15-guage...
I have a cordless paslode impulse finish nailer is missfiring. the battery is fully charged, the gas chamber is full.
Has the tool been striped down and cleaned lately? And are you using genuine paslode gas? If not, do these two fixes first and try again.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
Looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
My passlode 18 guage finnish nailer fires intermittently. Gas catridgev is good and battery is charged.it now only fires twice after it has been idle for a few minutes.Is this an easy fix?
This is awkward to diagnose. Sounds like a gas problem. Ensure the gas cell is in date. paslode print use by date on bottom. next ensure valve fitted to cell is correct normally yellow. When stopped firing press gas cell door (actuator) does it fire one more time? If yes it could be the actuator getting weak I have seen this cause similar problems to what you are experiencing.
Mar 30, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Black and decker 1802 nail gun will not fire with a fully charged battery
The battery may be falsely indicating it is completely charged when, in fact, it should be replaced
Mar 05, 2014 | Black & Decker Black Decker Firestorm...
Passlode im250ii
Not much information to go on. first thing to check is the date on the fuel cell. On the bottom of the fuel cell you will find a use before this date. fuel goes bad. next is tomake sure the battery is fully charged (light on tool should be green when you put battery in). With fastners in tool depress on wood. Now you should hear the fan start. Pull trigger and it should fire. If t doesn't, make sure there is not a jambed nail. Open quick release on front of tool. Remove jambed nail push driver back inside tool with small screw driver. Try to fire tool again, you may have to lift the tool again off the wood and press back down. when doing this you are putting fuel in the chamber and you might have to do it more than once. Hope this helps. please give more information if it des not. Good luck
Apr 25, 2012 | RTO Paslode 902000 IM250 Ii Cordless 16...
Rigid 18v finish nailer will not fire
Rigid nailer doesn't use gas... I'm having the same problem though.
Mar 17, 2012 | Air Tools & Compressors
Paslode impulse finishing gun wont fire. battery fully charged and gas is full.
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Jan 01, 2011 | Omega Paslode 901000 Impulse Cordless...
She wont fire, just bought from ebay
1.If fan is work check gas cell(use only paslode gas) and best before date(expired date)
2.If fan isn't working check that the battery is fully charged.
3.Make sure filter is clean and you can see through it.(no dirt or grit)
4. If after that it still isn't working you will have to take to your nearest paslode repair agent.(check on there web site for your local repairer)
good luck.!
Nov 04, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
My hitachi nailer wont fire
Start with the basics:
First check that the butane (or whatever gas is used) canister is full. If empty, put in a new one.
Second check to make sure your battery is fully charged to be able to fire the spark to work the nail gun. If not get the battery charged and/or replaced as needed.
Third make sure all of the safeties are working properly and that you have them engaged to the piece of wood you are nailing when you try the trigger.
If beyond that it does not work it could be a bad trigger, a bad safety switch, or even a bad connection from the battery to the device.
Nov 01, 2009 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Air Tools & Compressors Logo
79 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
