Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
The automatic bar oiler isn't working. What
The automatic bar oiler isn't working. What should I check or how does that system work?
    President:
  • 2,220 Answers
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
Example IPL Poulan 2375LE Gas Saw Type 2 (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Oiler components are on the "Handle, Chassis & Bar Assembly" print.
It has an outboarb clutch if necessary use this as a guide for removal. I think you need the special tool (Google Search):
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If the example is not your saw it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If You have more questions or need more help reply below and I will get back to you. HTH
Lou
Posted on Feb 07, 2010
How to fix chain saw automatic bar oiler?
possibly plugged up with sawdust blow clean with air compressor
Feb 16, 2015 | McCulloch Garden
Automatic chain oiler on my Partner s 55 chain saw doesn't work
First check the lines to make sure they are clear of chips. Use only bar and chain lube. If this does not work, the pump may be bad and need replacing.
Feb 09, 2014 | Husqvarna Chain Saw 20" Bar
Is there a bar oiler adjustment on a Poulan Wild Thing chainsaw
if you remove the bar and the tin guides you will find the oiler i have seen when not enough oil is getting to the bar there is saw dust built up on the outlet and if that isn't the case the pump could be week to remove the pump take off the clutch and there is 2 screws behind the clutch have also found those screws loose
Jun 09, 2012 | Garden
Automatic oiler has never worked well even when saw was new, chain never gets enough oil. Should I use a lighter grade oil, or what else should I check?
Take the bar off the saw and check that the hole that the oil comes out hasn't become blocked with saw dust. It sometimes happens also that when you are filling the saw with oil, shavings and saw dust can get into the tank and this can block the pipes connecting the tank to the hole that the oil comes out. Although it isn't really recommended, I have used waste engine oil regularly for oiling the saw. This works ok as long as there aren't any lumps in it.
Apr 28, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
The automatic chain oiler does not get oil to the chain. Yes, it has chain oil. The black tube to the top chamber at the bar, seems to be plugged and I cant get it off to clean it out. Thanks, Steve
I have never seen an automatic chain oiler that worked. Even new ones don't seem to work. Just pour a little used engine oil on the bar once in awhile like everyone else does.
In theory there is a small piston that rubs on an eccentric at the chain sprocket, and that sucks in oil and pushes it through a hole, into the center groove of the bar.
But if the piston is dry, it won't pump.
If the holes are clogged with sawdust, it won't work.
Here is a video that may help:
http://www.ehow.com/video_4756894_a-chain-saw-bar-oiler.html
Mar 12, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
My automatic oiler doesn't seem to be working......any thoughts?
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL). If cleaning does not work post back with a model and serial and I will provide an IPL (Huge help with disassembly and component location) and explain how to remove the clutch.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 18, 2010 | Poulan Garden
Automatic Oiler is not working on my Husquvarna 45
This usually means the oiler hole behind the bar & chain is plugged. you need to remove the bar & chain, clean the body of the chain saw in front of the sprocket/clutch assembly. look for a small hole & clean out using something like a toothpick & wd40 or penetrating oil.
Nov 15, 2009 | Husqvarna Chain Saw 20" Bar
Automatic oilernot working
Basics to check:
1) pick-up filter in tank clean
2) oil feed hole in bar clean
3) oil feed line from pump not cracked
4) pump worm gear and drive from under clutch (clutch removal needed)
Nov 11, 2009 | Poulan Pro Chain Saw 46cc 20"
Automatic oiler won't oil chain.
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 03, 2009 | Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
399 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
