Question about Lexmark X1240 All-In-One InkJet Printer
Fax problem When I am away from home I can not recieve a fax, when a fax is coming in I have to press start to recieve the fax. This has never happen before. I have always been able to recieve a fax even if I am not at home.
Now printer of colors
Posted on Feb 22, 2008
My canon jx210p fax receives all faxes into memory. how do i stop this and get it to print all recieved faxes straight away?
Hey!
If u briefly press the on/off button it will say auto print on and will print the faxes as soon as it comes in!
Good Luck!
Jan 12, 2011 | Office Equipment & Supplies
I need to switch my fax answering from manual to automatic. When its a fax and im not home i would like it to recognize that and receive the fax.
press function and recieve mode and keep pressing it until u get to fax/tel and preess start and then stop!
Apr 07, 2010 | Canon FAXPHONE L80 Laser
Brother Fax 2820 - The phone rings on it, but the fax come
Check if the machine is set on automatic recieve.
When on manual recieve, you'll have to start recieving manualy by pressing the button.
Jul 13, 2009 | Brother Office Equipment & Supplies
"no answer" on receive
If you are recieving faxes normal and you get this message once in a while its more likely someone is tring to call you via the phone or if you press the HOOK button and you press the GREEN start key the machine will go into recive and time out if it doesn't hear a fax tone within 30secs it will time out and give ypu this message.
Mar 09, 2009 | Canon LaserClass 7000 Plain Paper Fax
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
Recieveing
If all else fails try the manual mode:(Press Receive Mode to select
FAX ONLY, FAX/TEL,TAD:ANSWER MACH. orMANUAL.)
Manual Reception
Pick up the handset while the phone is ringing.
2 Press Fax Start if you hear fax tones (beeps).
3 When the LCD shows RECEIVING, replace the handset.
(best used when you are expecting a fax and know that the incoming call is a fax)
If you are like most people you probably also have a phone with an answering machine or voicemail setup on your home phone. If this is the case you may want to set the reception made to
TAD:ANSWER MACH.
May 28, 2008 | Brother IntelliFAX 2800 Laser Fax
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
When I attempt to fax something, a printout comes out that says it failed due to poor line condition. This never happened before and all the phone lines in my home work fine.
can you recieve faxes okay or isit just when you send ? you should know that your fax machine will not work properly if you get any staic in your phone line, you may want to check by listening to that particular line or you may have it plugged in the wrong socket. the correct one is the one labeled " L " or line and not telephone.
Thank You,
Mikey
Apr 05, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Can't send any faxes
Hello,Mafriend,It sounds like you might have recieved a Fax machine that Recieved a surge,To verify this Ck the Jack where the Phone line goes in to see if you have any type of discoloration there,also see if it locks up your phone line from making calls or recieving Them ttech
Jul 20, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
Lexmark X1240 All-In-One InkJet Printer Logo
87 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
