Question about Samsung Microwave Ovens
Samsung smh 7174, 7175, 7195. Everything works, no heat? The lights,timer, fan, and display board all work. But it does'nt heat the food.
fridgetech
  • 473 Answers
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Posted on Oct 10, 2007
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
SOURCE: Microwave won't heat food.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Posted on Nov 09, 2008
built in 3/94 is it worth fixing how much for magetron
Posted on Feb 12, 2009
  • 6 Answers
SOURCE: wiil not heat anything everything else works lights all looks and sounds like it working but nothing gets cooked!!
It might help to know the brand/model of the microwave, but in general, they are alike in some ways. Most have one, two, or three different switches that are part of the door interlock. This is to prevent the microwave from running with the door open (good idea). I recently repaired my 15 year old Panasonic microwave that had a similiar problem. You punched in the time, hit start, it "turned on", rotated, and sounded like it was cooking, but nothing got hot. Here is what I found.
I unplugged the oven and removed the back cover, it is usually all one piece with 6 or so screws. Inside the oven, where the door latch enters the frame, it is probably pushing on a piece that is activate one or more interlock switches. Chances are, that the switch that prevents the "power" components from turning on has failed. Over time these "microswitches" will go bad. I could "jiggle" my handle or push in on it "just right" and get it to work at times, but it needed replacing.
Now comes the part where you need a little electrical knowledge and a multimeter. You will need to check each switch to see if it has continuity when closed and that it opens up, electrically, when open. If you don't know how to do resistance checks or have a meter, ask around, you might be suprised by friends or coworkers that know how to do this. If not, you may be at the point where you will need to take it to a repair shop. If you can check the switches and find one that is bad, they only cost a few bucks, and you will be back in business. Reassembly is pretty easy.
This is the part that gets most folks, because they don't have a meter or know how to use one, a repair shop will probably want $50 - $100 bucks (minimun) and you can buy a new one for twice that. This is one reason our landfills are full of small appliance that still have a lot of life left in them. You can buy a cheap meter at Wally world or radio shack. If you want to give it a shot, follow up to this post, and I will try to walk you through this. Hope this helps.
Posted on May 30, 2009
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
No power to Samsung SMH 9151
The main fuse in the microwave oven has probably blown.
Mar 28, 2012 | Samsung SMH9151 Microwave Oven
My microwavedoesn't heat is there a fuse that may be blown
No! the fuse is fine, there are three likely causes, magnetron, "heats food" cracked high voltave diode, or a shorted high voltage capacitor.
Mar 24, 2012 | Whirlpool MH2175XS Microwave Oven
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Jun 24, 2009 | Samsung Microwave Ovens
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
Apr 16, 2008 | Kenmore 62702 Microwave Oven
Quit working
SE probably means a sensor error.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, it may have a problem with the control panelm such as moisture or contamination or a bad connection.
Let us know if the hard reset doen't fix it, and please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 12, 2007 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
