Question about Maytag MAV7600 Top Load Washer
Mav7600 won't agitate
Everything else works but when it trys to agitate it cant and just roars away like gears grinding.
It is your Transmission. Mine did the EXACT same thing just a couple days after your post. If you want some troubleshooting advice, part numbers, where I bought my parts, or advice on disassembly/reassembly, I will be glad to help. The truth is, I already wrote a detailed answer to your problem and before I posted it I read the "Terms of Use" page, and when I went back to the "solutions" page, everything I wrote was gone. So, if you want it, let me know and I will try again.
Posted on Mar 08, 2008
In park with engine running everything sounds fine and smooth as can be. all fluid levels are good. when i put it in gear it sounds and feels fine. when i start rolling i hear a roar. it doesn't drive...
You might have the front wheel bearings checked out. First drive it on some curves and bear left and then bear right see which way quiets it down. That really only works if it is in the front, however the rear ones do go bad as well, however it is usually the front ones that go with a roar. Hope this helps
Oct 01, 2010 | 2001 Chevrolet Blazer
Roaring sound on washing machine when spinning
Hi, It's more likely something caught in the pump or bad pump. Remove the belt under the machine and check the pump pulley for noise.
Apr 08, 2010 | Maytag MAV7600 Top Load Washer
The washing machine started making a grinding noise during wash cycle (minor) and a much louder grinding noise during the spin cycle. Is this a bearing? and is it replacable? Maytag MAV7600
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Jan 15, 2010 | Maytag MAV7600 Top Load Washer
I have a kenmore elite top load washing machine model 20957 and the agitator is not spinning, it sounds like gears are grinding so I removed everything from it and turned it off. Any solutions for this...
Hi'photogrrl80. I think I can help you. There is usually one bolt holding your agitator in place.It takes a ratchet with an extenderto get that bolt loose. then when the agitator comes outyou'll see these four little plastic gears that cause the agitator to do that motion washers do. Any good appliance outlet has the little gears for around $ 10.00. They are small but you'll see how they go back in. I've done mine twice. Good as new! good luck. You'll laugh when you see how much money you save by doing it yourself. Letme know how it turned out? skypope@live.com
May 04, 2009 | Kenmore Washing Machines
Maytag mav8600aww grinding when agitate
post your email i will send you the service manual
Jan 26, 2008 | Maytag MAV7600 Top Load Washer
Washer leaking water from bottom
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Maytag mav7600 agitator works and don't
Look at timer plug on harness for pins that are sticking out from side of timer plug, away from timer. See if they are all in the same amount. Sometimes one can work its way out so it won't make a good contact. Push in to plug if you find one.
Nov 14, 2007 | Maytag MAV7600 Top Load Washer
Atlantis MAV7700
Got to take front cover of washer to get  at the screws to take out... to get lid to lift up
Sep 15, 2007 | Maytag MAV7600 Top Load Washer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag MAV7600 Top Load Washer Logo
202 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
