Question about LG Xenon GR500 Cell Phone
When i slide it up the touch screen won't work
My touch screen won't come out
your slideing mechanism is jammed your gonna have to take the top off the cd player while its still hooked up and see were is it jammin at wen u try to open it the sliding wheels may just b outta grease if so put clipper oil or hair grease on it and then try it
Feb 13, 2013 | Audio Players & Recorders
My my touch 4g slide won't turn on. when i start it i feel a vibration but screen will not turn on. Help?
Dear:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 11, 2012 | Cell Phones
PHONE WON'T QUIT BEEPING WHILE TALKING
I just go this phone and it is complicated. It is a Touch screen phone and the Minute Minder was on "On" I thought I was getting a message while I was on the phone because the phone kept beeping. To turn Minute Minder off do not tap the button next to it that is blank but probably means off. Slide your finger across the line where it is highlighted and says Minute Minder to the blank square. Then the "Off" will show on the line. Don't tap it won't work--slide.
Aug 10, 2012 | LG Cell Phones
I have an HTC hd2 when I turn my phone on the slide thing on the screen won't slide, so the phone won't unlock. Sometimes it will work but not very often.
the problem is that your Touch Screen Digitizer is dying this happens to alot of HD2's from a year to about 2 and half years is when the issue starts to come to light. to fix it, it need to be replaced i suggest a profesional which can cost about 140 bucks or you can do it your self for 80$http://www.youtube.com/watch?v=eaaY0Dva8KQ
Aug 31, 2011 | HTC HD2 Smartphone
The slide bar will not slide to unlock on my ipod touch 2nd generation. I've tried restarting. It holds a charge and I can play it on my docking station. I can't use it by itself.
I had the same problem with my iPod touch 3rd Generation, the slide bar will not slide to unlock. I could however use the slide to power off at the top of the screen. I tried everything from rebooting it to a full restore and nothing worked. I finally took the Touch Screen Glass Digitizer off and the ribbon cable that connects to the board had come loose. I pluged it back in and everything worked again.
Aug 01, 2011 | Apple iPod touch Second Gen (8 GB,...
I dropped my iphone 3g and cracked the screen....I replaced the screen and now the bottom half won't work...it says slide to unlock...and it won't slide...but the top that says slide to turn off...
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
Jul 21, 2011 | Apple iPhone Smartphone
Touch screen stopped working
my touch screen stoped working i can still use all keys also i feel vibrate when touch the screen
helppp
Mar 07, 2010 | Samsung Tocco Ultra Cell Phone
Nuvi 660 touch screen will not respond
on top of the device there is a lock slide switch, make sure its not on the lock symbol, other wise it will lock the screen touch feature.
Sep 27, 2009 | Garmin Nuvi 660 GPS Receiver
LG Xenon GR500 Cell Phone Logo
26 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
