Question about Samsung Syncmaster 940BW LCD Monitor
My monitor will not power on with a working cable and directly to outlet
    Guru:
  • 239 Answers
Hmm, what u can do is that u buy an EXTENSION power cord...
Plug one in ur PSU & the other one to ur monitor
Posted on Feb 07, 2010
Monitor turns on for about half a second, then screen shuts off
There is a power supply problem and inverter board issue, cause usually bad capacitors in the above mentioned, sometimes they bulge at the top indicating they are open, repairs can run to the point that it may be cheaper to replace the monitor.
Mar 04, 2011 | Samsung Syncmaster 940BW LCD Monitor
I have a Dell 2007WFPb 20`` Widescreen TFT Flat Panel Monitor. I cant seem to power up. What is the problem here?
Here is one of the simple solution to your issue.
I suggest your try a different outlet, if your using a strip, try connecting it directly to the power outlet. Also most of the monitor has the same power cable as the computer, try swapping the power cable and make sure only the power cable is connected to test the monitor. If still doesnt power on, call Dell and have it replaced if still has a warranty if not, repalce the monitor.
I hope this resolve your issue.
Thank you for choosing fixya
Mar 04, 2011 | Dell 2007WFPB LCD Monitor
MY MONITOR SHOWS NO SIGNAL,I HAVE 15 PIECES SAME LIKE THAT PROBLEM,PLZ GIVE ME SOLUTION,MAY I REPAIR IT
  • Check for loose electrical and VGA cables. Remove the electric cord from the back of the monitor, then put it back in place. Remove the VGA cable from the computer and monitor and put it back in place. Make sure the connection is tight. If you're using a cable extender, remove it.
  • 2 Plug the monitor's electric cord into a different outlet. If you're using a UPS or surge protector, plug it directly into a wall outlet.
  • 3 Attach the monitor to a different computer. If the monitor still doesn't work, replace the monitor's cable. Make sure the cable is less than 5 feet long. If it still doesn't work, the monitor will need to be replaced or repaired. If it works with no problem on the other computer, troubleshoot your video card.
  • 4 Unplug your computer from the monitor and power outlet. Remove the cover. Pull the video card out of the slot on the system board. Push it back into place. Be sure the connection is secure.
  • 5 Put the CD that came with your video card into your computer's CD-ROM drive. Follow the directions to reinstall the video card drivers. Download a new version of the drivers from the manufacturer's website if necessary.
  • 6 Right-click a blank area of your Desktop. Choose "Properties" from the display menu. Click the "Settings" tab. Try different screen resolutions to resolve the problem.
  • 7 Determine whether the problem is caused by electrical interference. Electrical interference will make the monitor appear jumpy or wavy. Move any speakers, radios, fans or other items that can cause electrical interference away from the monitor.
  • Read more: How to Troubleshoot a Computer Monitor ' eHow.com http://www.ehow.com/how_2293087_troubleshoot-computer-monitor.html#ixzz17L812lWy
    Dec 06, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
    Fix my computer from black screen for free
    Here is the solution for your answer.Please follow the below steps to fix your problem.
    1. Check for loose electrical and VGA cables. Remove the electric cord from the back of the monitor, then put it back in place. Remove the VGA cable from the computer and monitor and put it back in place. Make sure the connection is tight. If you're using a cable extender, remove it.
    2. Plug the monitor's electric cord into a different outlet. If you're using a UPS or surge protector, plug it directly into a wall outlet.
    3. Attach the monitor to a different computer. If the monitor still doesn't work, replace the monitor's cable. Make sure the cable is less than 5 feet long. If it still doesn't work, the monitor will need to be replaced or repaired. If it works with no problem on the other computer, troubleshoot your video card.
    4. Unplug your computer from the monitor and power outlet. Remove the cover. Pull the video card out of the slot on the system board. Push it back into place. Be sure the connection is secure.
    5. Put the CD that came with your video card into your computer's CD-ROM drive. Follow the directions to reinstall the video card drivers. Download a new version of the drivers from the manufacturer's website if necessary.
    6. Right-click a blank area of your Desktop. Choose "Properties" from the display menu. Click the "Settings" tab. Try different screen resolutions to resolve the problem.
    7. Determine whether the problem is caused by electrical interference. Electrical interference will make the monitor appear jumpy or wavy. Move any speakers, radios, fans or other items that can cause electrical interference away from the monitor.
    Hope the above information will be helpful to you.
    Thanks for using Fixya.
    Nov 18, 2010 | Computers & Internet
    WHEN I PLUG IT IN THE SCREEN SHOWS THAT THERE IS NO VGA PLUGED IN. WHAT CAN I DO TO FIX THIS?
    Please just follow the below steps fix your problem
    Thanks.
    Oct 02, 2010 | Compaq Presario 5005 (470014-507) PC...
    ViewSonic VG2030wm speakers not working
    you are unable to get an image on your ViewSonic monitor, first check that the necessary cables are attached correctly and that the proper drivers are installed. ViewSonic offers drivers for download directly through its website (see Resources).
    Some LCD monitors use a VGA input while others take advantage of the newer DVI interface to provide a connection to PCs (some ViewSonic monitors offer both types). When connecting your monitor for the first time, you'll need the right type of cable for both your monitor and computer. In some cases an adapter may be necessary to convert the DVI signal from your monitor to work in a VGA input on your PC.
    Check that the VGA or DVI cable is tightly attached to the back of your monitor and to the back of your PC. Use the small thumb screws on the ends of the connectors to keep everything tightened in place, which will prevent the cable from getting loose.
    ViewSonic monitors also use a power cable to plug into a power source. If the power light does not comes on, check that the power cable is inserted fully into the back of the monitor and that it is plugged into a working wall outlet or a reliable surge protector.
    Mar 06, 2010 | ViewSonic VG2030wm LCD Monitor
    No power
    tried another power cable and plugged the monitor directly to other wall outlets. If that does nothing then go to http://www.viewsonic.com/support/customer-service/ and set up to ge the monitor serviced.
    Oct 27, 2009 | ViewSonic VP230mb 23.1" LCD Monitor
    Monitor power light flashes off and on. Monitor
    It could be any of the two. As a troubleshooting step, and I have seen this before, try connecting the monitor directly to the wall outlet and this being a new outlet. (sometimes a power issue)
    Do you have a extra power or monitor cables to rule out a cable problem?
    The VGA card could be mis-seated. Turn off the computer and re-seat the video card.
    Does the monitor screen show at Bios and is the problem only in windows? (in case higher resolution settting than monitor can handle)
    Jul 11, 2009 | Star Logic Monitor
    Dell e137fp monitor flashing green...
    Below you will find my recommendations for troubleshooting this issue:
    1. Reseat the power cord and verify a good power source.
    To reseat the power cord, follow the steps below:
    1.1 Power down the system.
    1.2 Unplug the power cord.
    1.3 Wait approximately one minute.
    1.4 Reseat the power cord.
    1.5 Verify that the power cord is plugged directly into a known good power outlet.
    2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
    To test the power outlet, perform the following steps:
    2.1 Unplug the monitor power cable from the power outlet.
    2.2 Plug in a different device, and verify that the device is operational.
    2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
    3. Verify the monitor is powered on and the power button is engaged.
    Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
    NOTE: There are two types of power switches:
    A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
    An electrical switch that has a short travel and almost no click.
    A lit monitor LED can be any of the following:
    * Green
    * Blinking green
    * Yellow
    * Blinking yellow
    * A combination, such as alternating green and yellow
    Any of these states indicate the monitor is receiving power and that you should proceed.
    4. Swap power cables.
    To try a known good power cable on the monitor, follow the instructions below:
    4.1 Turn off a working monitor.
    4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
    4.3 Unplug the cable from the monitor in question.
    4.4 Plug in the cable that came from the working monitor.
    5. Run the monitor self test.
    To run the monitor self test, perform the following steps:
    5.1 Power off both the computer and the monitor.
    5.2 Unplug the video cable from the computer or video card.
    5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
    5.4 Power on the monitor.
    NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
    If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
    Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
    Computer does not boot up.
    First of all, power down, remove all cables and check to see if your Graphics card is inserted correctly. Also try removing and re-seating the graphics card.
    Check the cable from graphics card to monitor. Also try cable and monitor on another pc to eliminate this possible cause.
    Failing that, you could have a BIOS problem.....did you recently try to flash your BIOS chip??
    Apr 05, 2009 | Soyo SY-K7VME Motherboard
    Open Questions:
    See all Samsung Syncmaster 940BW LCD Monitor Questions
    Samsung Syncmaster 940BW LCD Monitor Logo
    118 people viewed this question
    Top Samsung Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
