Washing machine Water level will not fill beyond half full
Water level will not fill beyond half full No matter the fill level that is dialed in the water stops filling at about half.
  • 572 Answers
If this is a commercial. thats as much water it gets. most of them are energy star
Posted on Feb 07, 2010
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
Water level
Need new vater level sensor switch
Dec 08, 2013 | GE GTWN4250DWS 3.9 cu. ft. Top Load Washer
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
Electrolux EW1045F, water filling stops at half level, not full
The pressure tube from the bowl could be obstructed. You will have to remove the tueb from the pressure switch and blow through it to see if it's not blocked firstly.
Jun 16, 2009 | Electrolux AW1001 Washer
No water gets in to the machine
ou should turn the dial to spin with lid closed for a full minuite, or blow on the tube at the water level switch. If problem persist replace water valve, if machine is agitating w/o water replace water level switch.
Mar 12, 2009 | Washing Machines
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
I have a 4 year old Maytag Performa washing machine. Regardless
Hi!!! You seem to have a bad water level switch..If you turn on the water and water just fills in and doesn't stop then you have a bad water level switch..If you just turn it on and water enters then you have a bad water valve..Good luck..
Jan 03, 2009 | Maytag Washing Machines
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
Hoover Premier 710 - always fills to capacity (can't adjust water level).
my one the same, I just adjust the water level switch to 60% then it work on full level, but no flood,I hope this help :)
Apr 30, 2008 | Hoover HTC243 Top Load Washer
Washing Machines Logo
193 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
