Question about GE Profile PDW8600J Built-in Dishwasher
Won't start-start/reset ligt not on
Ge profile dishwasher won't start-start/reset light not on when door is closed and latched
  • ed9857 Feb 07, 2010
    Thank you for such a detailed answer. I will follow it step-by-step tommorow. I will let you know if it corrects my problem.
    Ed
  • 311 Answers
Ok well ive noticed your question has been sitting in the expert forum for a while without response so I figured I would give this a shot for you. You will need voltmeter to complete the following steps. The very first thing that you will want to check is for 120v coming into the unit. To do so remove the bottom access panel and in the right hand side you will need see a small box. This is where your wiring to the dishwasher will be located. Remove the screw and take the panel off. You will have two wires that will be wire nutted together and a ground wire (green) screwed into the frame. Take your voltmeter and set it to AC current and stick your meter leads into the wire nuts if the meter reads 120v then you know you have proper power to the unit. If you dont have 120v then check your breaker/wall switches.
If you have 120v into the unit the next step would be to tug on all of your wires entering the door panel from the bottom of the dishwasher as these wires sometimes will get cut from rubbing on the sharp metal from the bottom of the panel. If you dont feel anything loose then you can move your way up.
I cannot pull up a good image of your specific model but am assuming you will have some type of micro switch assy to send power through to the control board when the latch is closed. At this point you will need to kill power to the unit. Open the door and remove the screws to separate the door. Set your meter to OHMs and remove one wire from the micro switch (you will have to manually activate it with a Flathead screwdriver and check for continuity through it) If you have continuity then the switch is good.
The next step would require fairly good schematic skills as you would need to check for 120v into the main control board. This would be your last step however you will want to be sure that it is a bad control board before you replace it because its about a 70 dollar part. Also check to make sure your ribbon cable is securely attached to the control board that feeds the touch pad.
Hope this helps _MJ_
Posted on Feb 07, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This issue can be either due to a faulty door latch or door lock switch which is not engaging itself. And, if the door latch will not engage the dishwasher will sense it as open door and will not start the cycle. You’ll need to get access to the fill valve by removing left panel, look at back to see where valve is when you get to it remove one of the wires and set meter to ohms setting and put a lead on each tag on valve. The reading you should be about 3.6k ohm if you don’t get a reading then the valve is at fault. I'll also suggest you to check the detergent dispenser solenoid for this issue. Remove the door panel and see if there is a round item at the dispenser assembly with two wires attached to it. Put the dishwasher into a cycle and when the noise appears, gently press on the solenoid to see if that is where the noise is coming from. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Feb 07, 2010
    Have you been able to resolve the issue. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
The start light is flashing on my GE dishwasher?
What's the model number? How old is this dishwasher? The new GE dishwashers (less than 3 years old) have a weakness in the door switch/latch assembly, and that would cause the light to flash - it wants you to press Start and close the door, but it's not recognizing that the door is closed.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 10, 2015 | GE Dishwashers
GE profile PDW9280J00SS dishwasher. It will not start. The keys on the keypad light up except the start buttom. I push start and nothing happens. all the other button are lit and i think work. Do I need to...
Possibly, but first, check the door switches and their cover to make sure they are OK. You will have to seperate the inner and outer halves of the door to get to them, located where the tub latch protrudes into the door.
Feb 05, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher makes a humming sound and has no lights on the control panel.It stoped and will not respond to any command
wiggle the door latch sometimes they get a little corrosion in the door switch and dont respond to the door being closed
Jul 26, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
Oct 16, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
May 10, 2009 | GE Dishwashers
START/RESET LIGHT STAYS CONTINUOUSLY ON
This is normal. The door latch has safety switch that will not let the machine do ANYTHING unless door is latched. If you need to do maintenance, then you can pry with a screwdriver, or possibly tape the switch so the machine can still run
Mar 01, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Dishwasher door will not open.tried running it another cycle and still nothing.It is a GE profile with the latch that you just push in. The latch/handle seems stiff.
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Sep 28, 2008 | Dishwashers
GE Profile PDW8600J Built-in Dishwasher Logo
75 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
