Question about Texas Instruments TI-84 Plus Calculator
HOW CAN I GET INTO THE ASK MODE ON MY CALCULATOR
  • Texas Instru... Master
  • 7,993 Answers
  1. Press [2nd][WINDOW] to access the Table setup screen.
  2. Use down arrow to move focus to the line Indpnt: Auto Ask
  3. Use right arrow to highlight Ask and press [ENTER]
  4. Focus moves to line Depend: Auto Ask
  5. Use right arrow to higlight Ask and press [ENTER]
  6. Press [2nd][MODE] to (QUIT) the table configuration screen.
  7. You can now create your table.
Posted on Feb 07, 2010
Change mode
To change the angular mode, press the DRG key then select the desired mode. To change the display mode, press 2nd SCI/ENG then select the desired mode. Or were you asking about some other mode?
Jan 29, 2014 | Texas Instruments TI-30 XIIS Calculator
Stats mode on canon F-710
Follow the instructions beginning on page 11 of the manual: http://www.fixya.com/support/p189012-canon_f_710_calculator/usermanual-FF2FEDF-pdf
If you have a specific question about the stats mode, feel free to ask it.
Jun 06, 2012 | Canon F-710 Calculator
The tangent and inverse tangent offer the incorrect sollution. whould i simply get a new calculator?
No, you don't need a new calculator. Yours simply has the angular mode set to grads. The inverse tangent of 1 is 50 grads, the inverse tangent of sqrt(3) is 66.6... grads.
To change the angular mode, press MODE one or more times until you get the display "Deg Rad Gra". Select the mode you want (from the results you're expecting, it's 1 for Deg).
Jan 26, 2012 | Casio FX-300MS Calculator
How do I put this calculator into regular math mode. When I ask it to solve 25/5 it gives me a fraction??
After calculation, just press key [SD] to display it as decimal number.
If you want to see solutions as decimal numbers press [SHIFT][MODE][2].
Please rate my answer if I helped you :)
Sep 07, 2011 | Casio FX-115ES Scientific Calculator
My numbers don't come out to be exact decimals in mode i put my float on number 1 and im trying to look for e with is apparently suppose to be around 2.78 but my calculator only says 2.7
Your calculator is doing exactly what you asked of it: it's showing you e (about 2.718, not 2.78) to one decimal digit.
Press MODE to bring up the mode screen. Use the arrow keys to highlight "FLOAT" on the second line and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Feb 10, 2011 | Texas Instruments TI-83 Plus Calculator
How to get the Z normal distribution values?
Note that this I'm using a Casio fx-991MS calculator.
I'm also assuming you're asking about the z value i.e. P(t)
You first need to go to SD mode, which is done by pressing Mode button twice where you'll get the choices as follows:
SD REG BASE
1 2 3
Press Numeral 1. you should see a small sd icon on the top of the display after you press 1.
Now enter Shift key + '3' i.e. Shift + DISTR and you'll get the options as follows:
P( Q( R( t->
1 2 3 4
Choose whichever is required.
Hope this is what you were asking about.
Jan 13, 2011 | Casio FX991MS Scientific Calculator
How do you turn off the scientific notation mode?
Look at the "cheat sheet" just above the display. Press either MODE 9 to select Normal or MODE 7 to select Fixed decimal notation. In the latter case, you'll be asked for the number of digits.
Oct 01, 2010 | Sentry CA 756 Calculator
Functions?
I am afraid I am missing something here. You can start with the expression of a function and have it graphed on a graphing calculator.
Or you can enter the experimental data, represent them on a graphing calculator and ask the calculator to find the curve that fits the data best, and once that curve is found to give you the equation.
However your calculator does not have the graphing capabilities. All you can do is enter the data and ask the calculator to perform a regression to obtain the expression of the function that fits best.
The available options for the calculator are accessible by pressing [MODE][3:Stat] and
2. A+BX linear
3: _+cX^2 quadratic
4: ln X logarithmic
5: e^X exponential
6:A*B^X power
7: A*X^B Polynomial
8: 1/X
Hope it helps.
Apr 14, 2009 | Casio fx-300ES Calculator
The calculator won't convert fractions into decimals
Are you using a ti-89? If so, check your mode settings and change Exact to Approximate.
Feb 06, 2009 | Texas Instruments TI-89 Calculator
How to graph linear equation in two variables
I am not quite sure what you are asking...
(1) if asking for graphing y= -2/3x+2, then press [diamond] [F1: Y=] type in .2/3x +2, see graph by [diamond][graph]
(2) if asking for graphing y= -2/3x+a, where a=3x, then first archive a=3x in Home screen by [home], type 3x [sto] a, then go back to y= menu, and type -2/3x+a in Y1
(3) if asking for graphing an equation that is dependent on 2 variables at the same time, use x-y-z axis (aka, change mode to graphing 3-D by [mode]graph [5:3D]) then enter desired equation in y= menu using Z function in terms of x and y aka z(x,y)= ...)
May 18, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-84 Plus Calculator Logo
539 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
