Question about IBM ThinkPad R40 2722 Notebook
There seems to be a short inside, the picture becomes out of focus and the cordless mouse has problems there is a small box on the bottom which my son open and wrap the thing in side with eleticial tape to makeit fit tighter and helped a little but not coppletely,unpluged it works fine while the battery is chared
  • dorisstaubin Feb 07, 2010
    well it comfirmed what I was thinking, I guess it's time for a new one when I can afford one...
    Thank you
  • IBM Master
  • 13,433 Answers
Hi the question is not quite clear, what is the problem and what kind of symptoms are you having exactly, what kind of problems is the mouse having? from what you told me it sounds like there is a hardware fault in the machine and it would require repairs at a professional, possibly the mainboard would need to be replaced but im afraid that is in most cases too costly to even consider since a new machine will cost you around the same price as the mainboard replacement would.
Posted on Feb 07, 2010
How Can I connect my wireless Logitech mouse to my laptop?
You should search for small wireless USB dongle (receiver) and insert it into USB port of your laptop. You bought The dongle with mouse. Sometimes it is placed inside mouse on bottom side. See picture.
A mouse driver is usually installed automatically in a while after the dongle is connected to PC.
Logitech M310 Silver 1 Wheel USB RF Wireless Mouse Model 910 001675
Jan 18, 2016 | Logitech Cordless Mouse
How do I open to change batteries
on the bottom of your mouse should be a small button like with picture of a mouse push that it will open up the top where your battery is located,hope this helped you.-poohma
Jan 25, 2010 | Logitech Cordless Mouse
I can't figure out how to open the case so that I can change the batteries
on the bottom is a small button with a picture of a mouse push that it will open the top of the mouse where the battery is.
Jan 16, 2010 | Logitech Cordless Mouse
IS THERE A BATTERY IN THE CORDLESS MOUSE RECEIVER FOR A LOGITECH TRACKMAN WHEEL
No, there's no battery for the cordless mouse receiver. The receiver is only getting a small amount of power from the USB ports of the computer.
Thank you!
Dec 18, 2009 | Logitech Cordless Mouse
My usb mouse broke and i would like to use another logitech cordless mouse but cant seem to get it to work...the red light is coming on under mouse so i think the battery is ok
There should be a small connect button on the receiver and one on the mouse.
Press the button on the receiver first, then the one on the bottom of the mouse.
Dec 09, 2009 | Logitech Cordless Mouse
I have two logitech cordless mice that have suddenly crossed signals while being operated in the same room. How do I get them to work independently again?
Typically there is a range limit to the cordless mouse to prevent this crossing of signals. Some have a connect button you can press to re-sync them to their respective module.
Some are on the receiver module (Small button on the front)
Some are found on the mouse on the bottom.
You could also disconnect one mouse temporarily.
Sync up the only live mouse then start the other short time after.
To prevent this from happening again later.
Try to move the mice further apart so the signals can't cross.
Oct 04, 2009 | Logitech Cordless Mouse
I have a Logitech wireless mouse that I cannot seem to get working on the computer i have a logitech cordless mouse JNZ201962 which i cant seem to operate even thou it says the drivers are installed
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Jan 16, 2009 | Logitech Cordless Mouse
I have a logitech cordless mouse JNZ201962 and i cant seem to operate it even thou it say the drivers are installed
Normal 0 Make sure the bateries are good.
Problem installing cordless mouse, model # cg t bb18, p/n 851497
Jan 13, 2009 | Logitech Cordless Mouse
Hotkey problems
I had the same problem but finally found a solution hidden in the depths of Logitech. It's quoted below. I had to do it a couple of times before it worked, and it seems that you need to reconnect the mouse at the same time. I didn't the first time and then the keyboard refused to work. (Finger trouble?) :-(
Cheers,
Magani
The following is from :-
http://logitech-en-ap.custhelp.com/cgi-bin/logitech_en_ap.cfg/php/enduser/std_adp.php?p_faqid=28&p_created=1083786523&p_sid=hwmEUpij&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTkwLDE5MCZwX3Byb2RzPTg0NCZwX2NhdHM9JnBfcHY9MS44NDQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1teCBkdW8gaXRvdWNo&p_li=&p_topview=1
This article applies to the following products:
Cordless Access Duo
Cordless Acess Duo Optical
Cordless access keyboard
Cordless Elite Duo
Cordless MX Duo
Cordless Navigator Duo
You may be able to reset the keyboard and resolve the problem by clearing the keyboard capacitors. To do this, remove the batteries from the keyboard and type continuously on as many keys as possible for one to two minutes. This action should simulate touch-typing; you should not press and hold only some keys down.
After you clear the capacitors, replace the batteries and synchronize the keyboard using the following procedure:
  1. Make sure the batteries are in correctly. A diagram on the device itself or in the Getting Started Guide should tell you the correct polarity for the batteries.
  2. Press the connect button on the receiver.
  3. Press the connect button on the bottom or right hand edge of the keyboard.
    NOTE: If you are using a Cordless Desktop System, you must do this procedure for both the mouse and the keyboard.
The "Connect" button on the mouse is quite small and usually requires a pencil tip or other small object to push it. Remember, ALL Logitech cordless devices will have a synchronization button. If you have the "Cordless Mouse" with Model Number (M/N) M-RN67, the button will be located in a small hole on the lower portion of the back of the mouse. You will need a paper clip to access the button.
Jul 03, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
IBM ThinkPad R40 2722 Notebook Logo
14 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
