Question about GE 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven wont light.clock is out. Unit had high voltage go through it.
  • 572 Answers
Replace the clock
Posted on Feb 07, 2010
Multi purpose oven won't work after power cut have reset clock, light won't work. Is making all the right sounds just won work
power supply from clock damaged not by power cut but voltage spike when power resumed the oven thinks its in auto mode permanentley thats why it wont come on ,new clock or power board needed.
Feb 03, 2017 | Neff Ovens
Ihave a Jenn-Air JMV8196 microwave oven. The clock works,the fan works and the light works. Not sure why the microwave will not come on to cook. Help?
The problem is caused by one of three things, the magnetron "heats food" the high voltage diode "sometimes shorts" or the high voltage capacitor " shorts"
Mar 10, 2012 | Jenn-Air JMV8196 Microwave Oven
My microwave oven stopped working. No lights, clocks etc. I have checked the outlet and it is fine, power available. Is there a fuse somewhere inside the microwave?
There is a main fuse in the microwave oven, "white body with silver ends" located near the high voltage capacitor. Unplug unit take top off and allow 30 seconds to dis-charge. Keep in mind the door switch becomes defective and often blows the fuse.
Mar 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have power at the outlet, nothing to the unit. worked fine last night. no clock no child reset not nothing. is there a fuse somewhere or a safety device?
There is a main fuse in the microwave oven, it is located under the keypad near the high voltage capacitor "silver and rectangular in shape" make sure unit is unplugged and dis-charge the high voltage capacitor for safety. I find the reason in most cases, that the fuse will blow if there is a defective door switch.
Feb 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
MY MICROWAVE OVEN CUTS OFF AFTER JUST A FEW SECONDS OF COOKING
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 17, 2009 | GE JVM1630 Microwave Oven
Clock works fan turn on but no airflow and time cook, reheat and surface lights do not work
Oct 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No heat in microwave
Oct 07, 2008 | Roper MHE14XKB Microwave Oven
Buzzing noise, wont work???
The magnatron is shorting, overloading the high voltage transformer. From the picture this looks like an older unit and is probably not worth a magnatron replacement.
Dec 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
No heat
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 28, 2007 | GE XL1800 1100 Watts Microwave Oven
Jenn-air ww30430p
this can be the light unit or the power unit supplying the voltage to the light unit. both cost about$150 each. I need a wiring diagram or know the voltage that comes out of the epower supply
Nov 14, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
GE 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
