Question about Onkyo TX-SR307 A/V Receiver
No audio output when playing dvd on PS3, although video and audio signal are reaching LCD TV. Connection made by HDMI cables
  • 30 Answers
Are your speakers working properly?
-K.R.
Posted on Feb 07, 2010
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
I have a new Denon AVR 1911 receiver all hooked up to my input devices and output thru a single HDMI cable to my Samsung LCD tv.... problem with getting audio from my DVD player: my DVD player is older...
Not likely that all those things are faulty.
The TV and DVD player make and model would be helpful to know. I would recommend running its BEST digital audio to the receiver and its stereo analog audio to the TV just in case you want to watch and hear the DVD in a lo-fi setting without the Denon. I generally advocate for connecting anything high-end (audio or video) ONLY to equipment that can use it or enhance it. Otherwise you may just be wasting expensive cable and adding unnecessary hops and connections that can fail.
Why do you want the audio to go from the DVD to the TV through the Denon? Are there no speakers on the Denon? Modern TV's have lots of inputs for the flexibility I recommend but rarely have decent audio or speakers.
May 06, 2011 | Audio Players & Recorders
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
You may want to try a good, Monster Cable, HDMI cable. Visit this page: http://www.monstercable.com/HDMI/advancedhdmi.asp
If you have a standard HDMI cable, it will not support 1080P.
So this is one of the few times that I will recommend spending the money for a better cable.
The better cable improves picture color quality, from 8 bit to 12 bit and it improves audio quality.
Dec 24, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Onkyo TX-SR307 A/V Receiver Logo
124 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
