Question about KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator
One door pops open when opposite side is closed
  • 572 Answers
It can as the air inside is pushed by one door pushing the other. if it popsit open and stays open, level the fridge backwards.
Posted on Feb 07, 2010
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
When I close the fridge side the freezer side pops open a little and stays open. The appliance is 5 years old. This started very recently
a couple of problems can cause door problems first open door and check seal for damage [popped off trac or rip-tears]other is hinges worn- bent-loose --if seal is good at top and bottom of door are hinges check for loose if loose tighten -if bushing lookes like a little round washer type is broken or missing replace --needs realignment loosen top hinge and close door and adjust till door is straight and stays closed tighten door hinge done good luck
Jun 28, 2011 | Jenn-Air JCD2389G Side by Side...
Garage door has a dirty grease mark down middle of door as if chain or something is rubbing on it.as it opens. When I watch it opens it appears that nothing is even coming close to door as it opens and...
When the door is opening the chain on one side of the rail is pulled tight and the opposite side sags. It is just the opposite when the door is closing. It could be the sagging side is rubbing against the door but it seems you would have seen this. Also the chain shouldn't have grease on it. Just a light coat of lubricant from the factory. You might try tightening the chain just a tad.
Nov 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
When we close the refrigerator door (side-by-side unit) the freezer door pops open slightly. The unit is about 14 months old and the seals look fine.
There is something not fully in place holding the door from closing completely. It doesn't take much. You should be able to feel slight resistance when opening if it is seated properly. The cavities are connected so when you close the door fast the air pressure moves from one to the other and pops the door open.
Eric
Oct 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Jun 17, 2008 | LG LRSC-26922 Side by Side Refrigerator
Dryer door pops open after running 5 minutes,close door hit start button door opens.let set 10 minutes ,run 5 minutes door pops open .dryer not overloaded. Serial #GEQ8811KTO
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Jun 14, 2008 | Whirlpool Dryers
Freezer door pops open.
normal operation actually, gaskets are designed to seal door closed not to hold them closed, first off check the items on the shelves make sure nothing stick to far out preventing good closing.next the refrig should be tilted slightly back. to aid in the doors swinging closed( the should close automatically form 45 degrees.)ok for them to "pop" open so long as they close back shut. this works on top freezers and bottomr freezer refigs, sidex sides use a differnet system of closing, if htats the case look into replacing door closures(cams) located under hte door assy
Mar 04, 2008 | Refrigerators
KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator Logo
291 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
