Question about ASUS Computers & Internet
My asus drw-2014s1t is detected by the computer but is not displayed in the list of hardware devices
    Problem Solver:
  • 11 Answers
It sounds like your computer can sense the physical device connection, but doesn't have enough information to recognize what is connected. The correct software may fix that.
The Asus website has a firmware upgrade for this device. The link may default to Windows XP, as you didn't specify your operating system. You can use the drop-down to change to a different OS.
http://support.asus.com/download/download.aspx?SLanguage=en-us
A firmware upgrade programs the information to your drive, upgrading its function. If it is not done correctly, it can cause your drive to become unusable, so its important to follow the instructions carefully.
Posted on Feb 07, 2010
Asus maximus iv gene z error code 45
A Windows Error code 45 will display or populate a error message that looks similar to the following:
Currently, this hardware device is not connected to the computer. (Code 45)
The device is not present or was previously attached to the computer. If Device Manager is started with the environment variable DEVMGR_SHOW_NONPRESENT_DEVICES set to 1 (which means show these devices), any previously attached (NONPRESENT) devices are displayed in the device list and assigned this error code.
What is the solution for this then?
To fix this problem, reconnect this hardware device to the computer.
No other resolution is necessary.
Visit also asus, and look for any driver updates for the mainboard:
http://www.service.asus.com/#!downloads/c1wax
Good luck
Jan 24, 2013 | Computers & Internet
My ASUS DRW 2014S1 which reading dvd but not cd. what's the reason
Reason:
Drive optical Lens is getting Weak either by dust and dirt or Wear and Tear degradation. First it stops CD reading and then DVD reading as well its normal behaviour
Solution:
If the drive is Internal type for Desktop you have the option to clean the Lens through CD lens cleaner with Brushes installed over the surface of CD.
If the drive is Tray type for Laptops then you have a better option to clean the Lens Physically open the Tray take a Micro Fiber cloth or you can take a Tissue Paper see the Eye like Crystal round thing that moves when you load CD this is Lens , please just take the Tissue paper and clean the lens with your finger Gently in Circular Motion do not use extreme force.
If it helps then ok otherwise you have to change the Drive now its about time
Please Rate me if i helped
Oct 03, 2011 | ASUS DRW 2014S1T - Disk drive - DVDRW /...
My dvd-rw is not ejecting when a cd is inserted. I have an Asus DRW-2014S1 dvd-rw. Please help..
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Aug 11, 2011 | ASUS DRW 2014S1T - Disk drive - DVDRW /...
DRW-1608P 3S - doesn't show on 'my PC'. On 'device manager' there's the name but with an exclamation mark over a yellow circle. My daughter was deleting old programs before, to make room for photoshop....
you need the drivers for this hardware (DVD Drive) also sometimes a firmware update is necessary in order for it work properly
asus-drw-1608p3s-u-1-24-firmware-vt1486.html">http://www.inetbridge.net/forum/driver-asus-drw-1608p3s-u-1-24-firmware-vt1486.html
this is direct link http://www.inetbridge.net/forum/download/file.php?id=1622&sid=db1912e34e9b2e8bf95cd864a78f2d2b for the drivers / firmware download
download the file, extract the content and it will do the rest. make sure to have your dvd drive connected to your computer.
Mar 09, 2011 | ASUS (GENEIRC DRW-1608P BLACK)...
I have an ASUS DRW-2014L1 dvd writer. somedays ago it has been dead and now if i enter any dvd or cd into it. it shows no disk in the drive pls insert a disk. now what can i do? A.B. Siddique
If it is not registering in your OS as a drive and doesn't map in BIOS then the drive is bad and needs to be replaced. It's about $25 USD from www.newegg.com or there are other brands around the same price.
Mar 08, 2011 | ASUS DRW 2014S1T - Disk drive - DVDRW /...
My computer doesn't register the ne.ASUS DRW 24B1ST - Disk drive - DVD±RW (±R DL) / DVD-RAM - 24x24x12x - Serial ATA - internal - 5.25" - black I had a ATA before and have now got a sata. The...
goto device manager,,...Open the "Run" dialog box by pressing and holding the Windows key, then press the R key ("Run"). Type devmgmt.msc.when it opens,right click the topmost icon,,choose "scan for hardware changes"..
sometimes,windows not show your dvd drive,unless you put a disk in.
Sep 15, 2017 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Asus drw-16008p3s won't detect cd/dvd
If it is Not detecting try Cleaning the cd lens with lens Cleaner Cd, if still problem persist Visit Asus Service centre in Your Country
Jul 09, 2009 | ASUS (GENEIRC DRW-1608P BLACK)...
Not Sure What Power Supply to use in my computer
750 Is PLENTY for your gear. Go hear and see. 750 can run 2 videos, 4 hard drives +
http://www.thermaltake.outervision.com/
Jun 20, 2009 | Thermaltake Toughpower 750-Watt Power...
ASUS DVD RW model DRW-1814BL
try reinstalling your operating system ( try format your cd or just repair it). The system will automatically detect the driver for your drive but if it was not listed in the bios try checking the cables attached to your drive.. or still if not.. the drive may be damaged.
Jan 22, 2008 | ASUS (90-N801W1000) DVD-RAM/DVD-RW Burner
DRW-1814BLT compatibility with IDE hard drive
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
Computers & Internet Logo
91 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
