Question about RCA F36705 36" TV
My rca 36705. The sound would cut in and out then stopped completely what could I check or do to repair this.
Why does sound cut in and out?
Sounds like the power amp is going bad..it might be a board for that repair...dont know alot about that model...
May 28, 2014 | RCA L46WD22 Television
The machine keeps cutting out during blending and mixing
need clarification. what does cut out mean? The motor stops altogether? The beaters stop spinning but you still get motor sounds? It comes on and goes completely off while in use and then comes back on. is there ever a bad smell or smoke? Are there any unusual sounds that you hear before it does a cut out or after it comes back on? Does it ever go up or down in speed on it's own. do the attachment gears on top spin while you are mixing in the bowl? we need to narrow the field of questions down to get to the right repair path. Please let us know.
Sep 18, 2012 | Kenwood Prospero Compact Km265 4.3 Litre...
Turn on/off flashes three times then cuts off complety
sounds like the CP150, CP120 and CP114 capacitors. You can get the RCA repair kit by the same name from www.tvrepairworld.com the kit also contains repair instructions.
May 16, 2011 | RCA HD52W59 HDTV Projection Television
I cut the RCA model F31672ET off and now I get nothing. It simply does not cut on. Before I cut it off the picture was getting very dark and I could not control the sound. Family members say it's not...
It sounds like your power supply board has gone out. This is a fairly common issue, and the repair will cost you around 175-300 dollars at a repair shop.
Mar 19, 2011 | Televison & Video
We heard a "buzzing" sound and it stopped when I
I had a similar problem. Everyone said must be the magnatron or the fuse ....turned out to be a burned out (visually melted) thermal cut out switch ($12) on the top side of the microwave. Had to get down inside the top of the microwave. The cut out switch was tucked away right up against the the microwave box. Hard to diagnose your problem without looking at the unit in question though, could be several different things. However, my philosophy when it comes to repairs...start with the cheap stuff first!
Jan 10, 2011 | Frigidaire FMV145K Microwave Oven
Have an RCA f32645 - sound cuts out to a static sound. Have reset overnight and sound will come on and randomly turn off again. The issue keeps reoccuring each day. What can I do to trouble shoot this...
RCA has had issues with there sound in this model. There are some capacitor and resistor modifications that will cure this problem. Your repair shop should have this info.
Oct 14, 2009 | RCA F32645 32" TV
My subs randomly go in and out, for no specific
wow..where to start..
First check your RCA"s by wiggiling them at the connection to the amp, see if this causes the amp to come on..If the amp plays then try swaping your RCA's.
Once you have checked the RCA"s, and other various connections, try simply bang arround on the amplifier, yeah I know, it sound back yardish, but if the sound starts to cut in and out by banging on the amp, then you know you have a bad soldier join somewhere. If this is the case, just have a technitian look at it, and repair it for you.
OK so you have checked your RCA's, and beat the amp up a lil bit, and still nothing.. Now you go beat up the dash board a bit, and see if the radio responds, if so then pull your deck, and find your loose connection.
There are still lots of things to check, but it gets pretty advanced, so try the things listed above, and keep your fingers crossed..
Aug 06, 2009 | Jl Audio 12W3 Car Subwoofer
Kept cutting on & off, then came on searching channels now is dea
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. Before paying a TV repair person $75+ to diagnose the problem, ask yourself if you're willing to pay $150 minimum to fix this particular set. Also keep in mind that if the TV is more than 3 years old, the availability of replacement parts can also be an issue. Normally it will cost at least $75 to have the set looked at by a repair shop (diagnostics). If the part needed to complete the repair isn't available, you won't get that money back.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Jun 18, 2009 | RCA F36673ET 36" TV
TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Feb 05, 2009 | RCA Televison & Video
Tv controls respond erraticaly
most of these rca models have bad flybacks. also check horz output transistor, if flyback is relaced the screen voltage has to be at or close to 295 volts or set will shut down after on 5 seconds
clintstv
Jan 18, 2008 | RCA 32V420T 32" TV
Televison & Video Logo
50 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
