Question about John Deere Tractor 50, 60, 70, ITJD10
I rebuilt a dtlx double induction M S Carb off of
I rebuilt a dtlx double induction M S Carb off of a John Deere 60. The dealer I bought the tractor from said to set the float level 3/4" from the gasket surface on the float bowl to the top of the float. When I turned on the gasoline at the sediment bowl, gas began to leak out of the intake side of the carb. 1. do I have the float level set correctly 2. is there another problem that causes this.
Thank you
Dan
3 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
rycgl
  • 1545 Answers
SOURCE: I cleaned my carb on
On most float-type carburetors, the float is usually perpendicular to the edge of the carburetor body when the needle is seated.Turn the carb upside down and adjust the float if necessary, to where the float is parallel to the carburetor bowl mounting surface. There are tangs at the front of the float where it hangs on the pin that can be bent up or down to accomplish this.
Posted on Jun 18, 2011
Could you rebuilt a clutch for a amt 600 John Deere or sell a new one
fixya site is an advice page only
we do not sell rebuild or have any parts for sale
all this is done by your local service dealer for the equipment you have
Sep 14, 2016 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
Why does my john deere l110 turns over but doesn't start and fuel is coming out of the exhauste
The float is stuck in the carb, remove float bowl and clean main jet and adjust float level.
Feb 24, 2015 | John Deere L100 Series
John Deere troubleshooting
Fuel starvation: Plugged filter or needle valve in the carb. The fuel is not getting to the carb fast enough to keep the float bowl filled.
Oct 30, 2013 | Garden
I can not get my John Deere 2020 to start. I have replace my battery, rebuilt the starter, and replaced the key switch. What else can I check?
the john deere 2020 gas tractor has a automatic reset breaker. If the tractor has a short it will shut off power to the ignition switch and reset in 60 sec. If the breaker is bad you will have power at the switch until you turn it to start or ecc.then no power at the ignition switch. I can not find the breaker. let me know if you do.
Sep 04, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Whats causes my john deer 2010 gas to run onily with choke out ? Had carb rebuilt and tank cleaned. will low compression cause this?
i have seen about 4 of these have the solenoid on the bottom of the carb stuck closed was able to clean 3 out of the 4 there not cheap so try hard to clean it also had a few briggs engines have bad safety switches shut them off so check for power and ground
Jul 08, 2012 | John Deere 2010 Tractor Basic Carburetor...
John deere gx345 has no spark at plug what is the cause?
need new coil pack or have short in harness grounding engine from running. check fuel line to carburator. 1. take float bowel off bottom of carb. do not touch float or pin holding float. crank engine over until fuel comes out of carb. If fuel comes out, you don't have fuel problem. put float bowel back on carb. 2. check for spark. take spark plug out of mower. put wire back on plug and place the threads on head [or metal of engine to ground the plug]. crank engine over for a few seconds to see if plug gets spark . [always double check with another spark plug that is good]. [[ Remember!!! you have to have someone sitting on the lawnmower to start. unless you by-pass safety switch [only do this if you understand how the safety switch works. NOT EXPLAINED HERE!!!]] If spark is present, there is no grounding problem. when engine is cool. 3. CHECK COIL PACK. for continuity. When the coil pack gets hot it will stop any juice to the plug. A>Check temp sensor B> Check Safety switches grounding out. C> Check for cut wiring harnes. [loose wires rubbing against pulleys, wires cut by rodents]. Hope this helps.........................GAS
Jun 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
I cleaned my carb on onan 318 john deere , now the needle and seat is not shutting off the gas . what is the proper float level adjustment
Jun 18, 2011 | John Deere Garden
John Deere Tractor 50, 60, 70, ITJD10 Logo
48 people viewed this question
Top John Deere Toys Experts
Jim Goldsmith
Jim Goldsmith
john h
Charles T Nevin
Charles T Nevin
Are you a John Deere Toy Expert? Answer questions, earn points and help others
