Question about Electrolux EOD5310 Electric Double Oven
Grill door removal
How do I take off the grill door so as to replace the inner bonded glass panel? I've removed the hinge screws but it still seems not to want to come off. Any help much appreciated.
  • 60 Answers
You have to remove the glass front to access the screws to secure the grill
Posted on Feb 22, 2008
HOW CAN I CLEAN BEHIND CONTROL PANEL TO REMOVE FATTY DEPOSITS ON THE BACK OF THE GLASS
The deposits can be a bit of a challenge as they re on the inner door glass and may be cooked on the glass. You must remove the door off the hinges first and then remove the inner door panel. It will be attached by screws. Once the inner panel is removed, you can remove the glass and clean it with a product called Goo Gone.
Oct 25, 2015 | Ovens
Glass panel missing on grill (top oven) door?
if there seems to be a hole there and not a solid door then yes there should be glass there. try doing a goggle search on the brand . there might be a pic there to show you what is should look like.
Nov 12, 2011 | Ovens
Stoves E2H600- lighting behind fascia panel has gone off so cannot now see what temperature settings are! How do you remove the fascia panel to access and replace defective lighting unit/s? Many thanks,...
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Jun 22, 2011 | Stoves Ovens
The front glass blew out of it! Completely shattered and no one had touched it. Now we need to clean it up. I suppose we need to take off the door and get a new one. OR do we get a new glass plate and...
Hi and welcome to FixYa I am Kelly.
Since you did not include a model number this solution will be from the hip as I can not refer to any manuals to assist you. Most ovens the oven door comes off by tilting the door out to the first stop and then lifting is vertical inline with the position of the hinge at the bottom of the door. Some of them may have retaining screws on the inside of the door to keep the door attached to the hinge area that must be removed FIRST. The hinge itself should stay attached to the oven.
I can probably provide you with a source (Maybe more than one) for the door glass if you respond with a model number,
When you attempt to take the door apart lay it down on 2 rugs so you do not scratch it. Use some blocks of wood UNDER the rugs to prop the door up so as not to damage the handle.
The door glass is replaced by removing the screws from the indide of the door. Sometimes you have to remove the trim pieces in addition to the multiple door panels. Everything is done from the inside of the door. You must take out the inner panel, Then the inner glass, then the spacer, the insulation if any and finally the outer door glass. Reassembly is in reverse order. Outer glass, spacer, insulation if any inner glass, the inner panel and re-install the trim if you had to remove it.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Ovens
It is a double oven, but I want to eliminate the lower oven... so, I am looking for an electrical plan so I can find out how to disconnect the lower oven... and only install the top part.
•Step 1
Open the oven door to the half open position. Locate the hinge on each side of the oven door toward the bottom. The top center of each hinge has a hole. Insert a nail or screw into the empty hole on each hinge to prevent the hinge from closing inside the door rail after disconnecting from the oven.
•Step 2
Grab the sides of the door with your hands and lift straight up to disengage the hinge from the door. Push down slightly on the top of the door to release it from the hinges. Pull the door away from the oven and place it on a flat surface with the door handle toward the floor.
•Step 4
Using a Phillips-head screwdriver, remove the two screws at the top of the inside door panel that secure the inner door panel to the outer door panel. Loosen and remove the three screws on the bottom edge of the oven door with the screwdriver. Lift the inner panel away from the outer oven door.
•Step 4
Loosen the two screws that secure the door handle to the outer door panel. Lift the outer door panel slightly to pull the handle away from the door.
•Step 5
Remove the screw at the top and bottom of the side hinge rails with the screwdriver. The hinge rails mount to the outer door panel and the inner panel sits between the rails. Lift the hinge rails off the outer panel.
•Step 6
Lift the inner door glass straight up out of the outer door panel. Stand the outer door panel up on its bottom edge. Pull the top trim off of the door panel and outer glass. Hold the top of the glass panel and pull the two side trim pieces away from the outer panel. Pull the outer glass away from the outer pan.
once it comes out you can do what u want.
Jul 27, 2010 | Ovens
Hi. The outer glass grill door has come away and smashed on the floor when going to open grill by the handle. Can't see that there were any screws in the bottom of this. Would they have been factory...
Sometimes the glass is bonded to the door (glued) which may be why you can't see any screws.
It seems as if you are going to need a new grill door complete.
Dec 30, 2009 | Electrolux EOG9330 Gas Double Oven
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
Electrolux EOD5310 Electric Double Oven Logo
170 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
