Question about Tappan TGF364AS Gas Kitchen Range
TAPPAN MODEL 3 TGF367CFSA, GETTING A F3 CODE, OVEN DOES NOT WORK
My tappan model # TGF367CFSA Gas Stove is giving me a F3 Code. I don't what could be the problem, the top burners work but the oven doesn't. I changed the igniter but that didn't help I still get the F3 co
  • 149 Answers
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
Posted on Mar 27, 2010
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
F3 and f2 codes on Tappan stove model 30-3991-00-03
1. Test harness/connections P4 (EOC) and P11 (Surface Element Control Board). 2. If harness checks correct, failure can be caused by faulty UIB, Surface Element Control Board, or EOC. Check harness and connectors from the EOC to Mini Oven Control Board. Check for 15VDC to Mini Oven Control (red and gray wires). If harness and voltage are good replace Mini Oven Control. If fault returns replace EOC.
Aug 24, 2012 | Tappan TGF320 Gas Kitchen Range
Tappan stove model # mef352bfwa and serial # vf72904759 . When using oven F3 shows up on display and oven shuts off.
Hello & Welcome to FixYa
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 18, 2011 | Tappan Kitchen Range
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Kenmore Model 665 95781000 Stove Displays a EO-F3 code and the oven does not work WHat part work be defective to give me this fault code EO-F3?
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | Ovens
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
Unlock my Tappan Gas Over Door?
Hi wewada,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Aug 03, 2008 | Tappan TGF320 Gas Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Kitchen Ranges Logo
345 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
