Question about Toshiba COPIERS E-STUDIO 600 Copier
Toshiba E-studio 600 display F130 error
I've changed my SYS board of my toshiba e-studio 600. The copiers keep showing the error F130 (MAC address not assigned). Is there a way to assign the Mac address or to fix the problem ? ( I do not use the copier as a printer )
I formated the hard drive ( 08-690-2) and rebuilt the database ( 08-684 ) , but it could not help.
Thank you in advance!
  • dragonsla972 Feb 08, 2010
    Thank you!
    There was also a guy who told me to do that. But I thought it could not solve the problem so I did not try it yet.
    I solved the problem myself anyways. I tried to initialize the board by 08 - 665 ( I was too nervous trying using this , haha)and the problem was gone.
  • Toshiba Master
  • 643 Answers
The NVRAM on the SYS board stored information of MFP such as counters, serial number, settings and etc.
If u swapped SYS board, then the serial number of MFP will be different. U need to assign the correct Serial number at 08-995.
Or, use back your original NVRAM on your new SYS board.
Posted on Feb 07, 2010
Testimonial: "Thank you so much! "
Hello sir copier Toshiba e studio 600. when I turn it on it shows 19 vertical lines standing in the screen display. Also it is still warming up .it makes me not able to copy . Please help me. Thanks
Display panel is properly shot. as warming up. try taking the toner bottle out after powering off. then power it on without he toner bottle let it go thru its cycle when asks for toner install
try this site for additional info
Toshiba STUDIO 520 523 600 623 720 723 850 853 Service Manual free...
Oct 19, 2015 | Toshiba Office Equipment & Supplies
I Purchased a GM-2041 for our Toshiba e studio 600 Copier, Plugged it in and lt lights green but I still cannot print (Still get :4030 Error) what am I missing? how do I enable the print function?
GM2041 is Print/Scan dongle. Did u able to do scanning? I've encountered before for 4030 printing error, due to print dongle faulty...
By the way, did u enable the trial period where network printing is performed after the termination of a trial period? U might need to disable the trial period then only u plug in the dongle.
Jul 10, 2012 | Toshiba COPIERS E-STUDIO 600 Copier
Error code on toshiba e studio 350 code is f110
Communication error between System-CPU and
Scanner-CPU
Check if the harness connecting the SYS board and SLG board is disconnected or open circuited.
Replace the SYS board. Replace the SLG board.
Mar 07, 2012 | Toshiba e-Studio 350 Copier
The copier is giving error code f07
F07 Communication error between boards (LGC and SYS boards)
Firmware is where I would start along with the wall power.
If this isnt work, replaced logic board and updated firmware. Machine will must works perfectly.
Hope this helps.
Oct 12, 2011 | Toshiba e-Studio 45 Black and White Copier
F10 error after getting moved
the error is communication error between system cpu and scanner cpu
check the following
(1)check the harness connecting the sys board and the slg board is disconnected or open circuited
(2)check the version of the system rom on the sys board
(3)check the version of the scanner rom version on the slg board
(4)replace the sys board
(5)replace the slg board
but first try doing the latest version of firmware
Mar 14, 2011 | Toshiba e-Studio 35 Copier
Its showing mechine reboot CA90
[CA90] indicates Image data transmission error of sys board.
Check the harness between the PLG board and SYS board open-circuited or the connector dis-
connected?
If the harness is ok, then probably is the PLG board & SYS board issue.
Nov 09, 2010 | Toshiba E-STUDIO 850 Copier
I copy new ROM on system board - error F130 Mac address not assign - please help me how to fill serial number at mode (08-995) Thanks a lot
Hi how are you this is jack my mailing ID (jack_pak@hotmail.com)
Dear follow the procedure step by step.
[F130] Invalid MAC address
Compare the serial number of the equipment with a number displayed in 08-995. If they are different,
enter the correct serial number at 08-995.
Dear check the serial no 08-995 and simple change the correct no.
when you 08-995 pree copier show a windows on the panal
check S.No ... press C buton and enter correct S.No and press the ENTER Buton.. ( correct S.No.you can check the copier back cover)... please vote me.
Thanks
Best Regards,
Jun 10, 2010 | Toshiba COPIERS E-STUDIO 520 Copier
656 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
