Question about Compaq Presario Notebook
I have a laptop and a tv. I would like to hook my laptop up to the tv. The tv does not have a slot for a VGA CABLE and my laptop does not have a slot for an RCA CABLE. What can I do to connect the two?
  • Compaq Master
  • 12,061 Answers
You need an Video out, adapter cable, for your model Laptop, IF yours indeed does have the ability to TV out, the "output" is "Composite Video" and goes into the Composite Video "IN" on the TV. Audio is taken from Line Out in laptop & goes to AV audio in, via a Phono Jack to RCA converter plug. Also it must have correct drivers and be enabled and have desktop extended to the TV either Cloned or Spanned.
Usually one connects up to the TV, powers TV on & then Turn your laptop on.
You may have a Yellow RCA socket on the back/side of your laptop, otherwise you have to get a converter cable.
Posted on Feb 07, 2010
How do i hook my compaq preario cq56 laptop to my hitachi hd plasma tv
The laptop looks like it has an external VGA port only and without knowing what model of Hitachi tv it is. It is quite possible the tv may have a VGA input in which case a standard VGA cable will allow you to connect the laptop to the tv. Otherwise you will need one of the following depending on what connections the tv has:
1. VGA to HDMI cable: http://www.amazon.com/Video-Cable-Black-Support-Necessary/dp/B002TUC64W/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697785&sr=1-1&keywords=vga+to+hdmi+cable
2. VGA to RGB cable: http://www.amazon.com/eForCity-Premium-Component-Cable-Black/dp/B0012SPNII/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697879&sr=1-1&keywords=vga+to+rgb+cable
If you do not have an HDMI input, you will also need to get an audio cable as well. Standard mini-stereo audio cables should allow you to connect the laptop to the tv.
Dec 16, 2012 | Compaq Computers & Internet
I need to connect acer aspire one to my technika tv can i do this through hdmi ? if so what cale do i need to buy
If your version of Aspire One has an HDMI slot then yes - it will work. Every HDMI cable, even the cheapest one, will work.
But regular Ones have just a VGA connector and only a VGA cable in a VGA slot of the tv will work. If your tv doesn't have that slot then you cannot connect it to the laptop.
Apr 18, 2011 | Acer Aspire One PC Notebook
How to hook a laptop to my tv. What materials do I need.
your tv has to have a vga input and you will need a vga cable connect the blue vga cable the vga output from your laptop then go to the menue on tv screen then select vga on you tv screen and that should do it
Feb 09, 2011 | Magnavox 42MF439BF7 42 in. TV
How do I hook up my Compaq Presario CQ62 laptop to my HDTV LG
If the laptop has an HDMI output - that's the preferred way. However, the VGA is another - then you'll need a VGA cable from the laptop to the TV's VGA input.
Dec 26, 2010 | Computers & Internet
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
Does it have s video out let ? where is it?
It has a VGA slot for sure, u will have to source a VGA cable and connect it to VGA outlet in the TV ( provided it has a one )
Hope it helps..keep the hope :)
May 19, 2009 | Dell Latitude X300 Notebook
How to connect samsung plasma tv to a toshiba laptop?
to get high definition you will need to use either the vga or dvi output from your notebook and connect to the DVI input on the tv, vga connection on the tv will only give 480i whereas dvi will give upto 720i
Nov 04, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Compaq Presario Notebook Logo
152 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
