Question about Goodman GMS90703BXA Heater
Blower does not work and heating element heat with
Goodman model AR42-1 blower does not work and heating element heat with thermostat is off
  • 456 Answers
If you recently put in new thermostat make sure you
put the wires back where you took them off. Turn
unit off,remove blower compartment door. Find where
thermostat wires connect to board, G-terminal is usually the control wire for the fan. W1 or W2 terminals are usually resevered for the heat leg. Disconnect them both, put those wires out of the way, Put door back on and turn power back on
nothing should be operating. Turn power off
Remove thermostat and find what color wires go to
W1 or W2 and G. Put thermostat back together,
go to the indoor unit where you were before,
Whatever color wire you had at thermostat W1 or W2
connect on the control board to W1 or W2. Do the samething for the g terminal or what is called the
fan leg.
Good Luck
Posted on Feb 07, 2010
    Guru:
  • 415 Answers
Check for power to the unit. If power exists, check your low voltage. Do you have 24volts to R & C at your thermostat?
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Jan 07, 2013 | Goodman Manufacturing Goodman HKR-10C 10kW...
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Estate Dryers
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
Finding Pilot light on Goodman Model caf024a2a. Cannot seem to find the pilot light...The blower works but no heat.
i think the ca # is for the cooling coil unit - the heater should start with gmXXXXX - if your unit is fairly new - the pilot light electronically when thermostat calls for heat the unit will not light if the burner door is open
Oct 24, 2009 | Goodman Heating & Cooling
NO HEAT
A blower relay usually has a set of closed contacts that go to the  motor and when the 1st element comes on the power goes on through the sequencer and then these contacts and to the motor heating speed. If you have a blower in AC and with the fan sw to ON u can run the blower on manual 100% of the time until someone can come look at it and the heater coils will cycle on and off with the thermostat. Dont worry about the cost compaird to the elements the motor is nothing and the heat it generates is going into the heated home anyway.
Feb 28, 2009 | Goodman CPLE24-1 Air Conditioner
My goodman heater is working but the blower turns on when my induce motor turns on too model GMS81405DNA
sounds like the thermostat is set up to control the fan with a call for heat(usualy the way we set up a heat pump system) New thermostat?
Jan 10, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
212 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
