Question about Philips 32PFL3403D/27 32 in. LCD TV
Trouble with Philips TV LCD 32PFL3404/78 after use of SERV. MENU
I´ve changed de PROJECT option inside the service menu. Now TV is still turning ON, but nothig appers. How can I reset the factory setting?
  • 231 Answers
SOURCE: I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Posted on Aug 26, 2009
circuitworld
  • 335 Answers
SOURCE: 42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Posted on Nov 03, 2009
SOURCE: Total Factory default of Philips 37pfl9703
hi, I found the solution, and tested myself on a 3000 series LED tv from PHILIPS.
press 062596 and then press i or info button.
you will enter service mode.
go to the function number 0043(if i remember well)
this function will have the option to press ok to reset.
press ok and for a second the "press ok" message will stop from blinking, then will keep blinking.
go to the final function from the list, which is exit menu
press ok
turn off tv
when you turn it on again, the tv will be as turned on for the first time and ask you country and lenguage, etc...
good luck!
Posted on Aug 08, 2010
jyackle5
  • 8197 Answers
SOURCE: How can I reset my
press ok
turn off tv
good luck!
Posted on Jan 12, 2011
gopakumarg43
  • 75304 Answers
SOURCE: Philips 32PFL3505D 32 in LCD TV How can the TV be
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Posted on Mar 08, 2011
Samsung Tv flipped upside down
Most Projector tvs usually have a mode for hanging them from the ceiling, as well as a shelf top.
Go to menu, settings, and then ceiling.
This option will convert the picture to project upside down.
Mar 19, 2014 | Samsung Televison & Video
I want to know how to open the service menu on my LG tv
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Check this link too.
Oct 30, 2012 | LG 22LG30 22 in. LCD HDTV
Samsung LN22C350D1D FACTORY SETTINGS??
1. Do what you did, enter to service mode, and reset to factory default.
2. Use the component cable (green, blue, red, white, red) connect your set top box to the TV’s component input.
May 10, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Sound problem
when you mail me,i have an service manual for you
haas1@kabelfoon.nl
Apr 02, 2010 | Philips 20DV6942 20 in. TV/DVD Combo
I have a LG tv and now i can´t get any colour???
Do a hard reset, there is a setting in the menu to put the set in monochrome mode, i think that is what has happened
Jan 07, 2018 | LG 37LE2R 37 in. LCD TV
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
hold down menu button on set until it does a factory reset
Dec 07, 2008 | Philips 32PF9966 32 in. HD-Ready LCD...
Samsung LCD TV LN40A650 - Service Mode
1. Turn off the TV
2. Press "info" then "Menu" then "mute" and then "Power" on your remote (As fast as possible).
The TV will now start up in Service Mode
Breinholm / Denmark
May 23, 2008 | Samsung HP-P3761 37 in. HD-Ready Plasma...
Unable to exit TV's menu
Try to replace the remote sensor board inside the bottom of your tv. If that won't work, you need to replace the Small Signal Board (SSD Assy) of your tv.
Nov 24, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 32PFL3403D/27 32 in. LCD TV Logo
510 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
