Question about Sharp Heating & Cooling
Describe your sharp portable air cvP10PC Problem - the window installation components not being able to secure them with 4 screws to fit a 39 inch tall window (slider, left to right)
SOURCE: I'm confused by the window kit - help
You will have to cut the slider to fit. It comes extra long in case you want to install it length-wise (up and down) in a sliding door.
Posted on Jun 28, 2007
  • 4736 Answers
SOURCE: Hi I've just purchased a used
Harry. if you purchased it from a brick and mortar store, rather than online. Return it to the store for replacement. Or you can get it from Haier under warranty, with your Proof of Purchase. It's more to it than just the air intake and the exhaust hoses.
You can contact Haier Customer Support at 877-337-3639.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 02, 2011
Testimonial: "thanks for your help - very useful"
  • 961 Answers
SOURCE: Hey there...I've had my Sharp
Sound like the unit is working fine and there is alot of humidity where you are at, thus having to drain the unit. I'm assuming this is not a window unit. Anyway, you need to make sure that the collection bucket is collecting all the water,ie; Nothing splashing past it and/or a hose leaking outside the bucket instead of inside. Check any insulation you may see on the tubing to make sure it's not damaged or allowing water to leak where it's not supposed to. If the bucket overfilled, there also may be residual water leaking from the bottom. It would be a shame to get rid of aunit in working order.
http://www.sharpusa.com/CustomerSupport/ContactUs/ContactUsProductSupport.aspx
You could try contactingSharp
Posted on Jun 05, 2011
  • 4736 Answers
SOURCE: I just purchased this portable air conditioner. I
LG does not currently have an extender panel. However, call Vance Baldwin/Encompass at 1-866-779-7906, as they may can help you with that.
As far as noise is concerned: Generally speaking, most noises heard from the air conditioner are normal sounds of operation. Most of the time, noises are muffled during the day by activity in the home, but heard at night when it is more quiet.
Vibrating Noise? This is most likely the result of improper installation. Check that the unit is secured properly in the unit. Make sure the filter and the front grille are attached properly.
Hissing/Gurgling Noise? At the ON/OFF operation is caused by the refrigerant flowing inside the air conditioners sealed system. THIS IS NORMAL. This sound is a little louder for 2~3 minutes when the unit is first turned on. This is the sound of the compressor start-up. THIS IS NORMAL.
Beeping sound when control settings are selected/changed? THIS IS NORMAL. This noise is a signal that the control panel settings have been changed.
Pinging Noise? THIS IS NORMAL. This is the result of moisture in the base pan being picked up by the fan (called a slinger fan) and thrown against the condenser. This helps to discharge the heat and make the unit cool more efficiently.
Is the unit installed in an enclosed are? A unit enclosed by many walls is likely to produce more noise as the sound waves will be reflected and echoed.
Once the room temperature is met, the compressor should turn off automatically. But, the fan may run for several more minutes.
I hope this helped you. Thanks for choosing FixYa.
Posted on Jul 24, 2011
  • 4736 Answers
SOURCE: I was given the kenmore/danby 461.35723-7 portable
The model number you listed didn't come up for Kenmore. However, the similar Danby model's Owner's Manual may help you. You can download and print it for future reference.
http://www.danby.com/cms/uploads/products/en_manual/DPAC12010H-EFOM.pdf
Posted on Aug 07, 2011
How do I remove plastic housing from Sharp CV-P10MX portable air conditioner to clean dust from inside.
It should be clipped on with a type "S" clip. If there are no screws visible, gently work all sides and pull towards you.
Apr 29, 2014 | Sharp CVP10MX cvp10mx 9 500 btu portable...
Window kit dimentions i have a window 18 inch wide
The portable AC units generally have a customizable, exhaust hose window, termination kit that comes with the unit.. In other words it can be cut to fit. The one that comes with the unit will fit casement windows, as well as sash windows.
To further assist you, I have included a link to the Owner's/Installation Manual for the model you referenced. You may download and print it if you like.
http://www.air-conditioner-home.com/manuals/ac-12000.pdf
Jun 13, 2011 | NewAir AC-12000E Portable Air Conditioner
1997 mercury grand Marquis driverside rear window motor works but window won't go up. Inner door panel off. Metal cable with a black foam cover and pink plastic clip off. Can't figure what it fits to.
usually this means you need a new window regulator.
Section 01-11: Glass, Frames and Mechanisms 1997 Crown Victoria, Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Window Regulator, Power Front Door
Removal
  1. If front door window glass (21410) is in the down position and is inoperable, the following steps must be taken; if front door window glass is operational, go to Step 2.
    1. Remove front door trim panel (23942) and front door trim shield (237A04). Refer to Section 01-05 .
    2. Disconnect battery ground cable (14301). Refer to Section 14-01 .
    3. Disconnect window regulator electric drive harness connector.
    4. sva~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Be careful not to strike or scratch front door window glass because it can break.
      Remove window regulator electric drive retaining screws through holes.
    5. Remove window regulator electric drive (23394) from front door power window regulator.
    6. Raise front door window glass to full up position by hand and secure with tape.
    7. Go to Step 5.
  2. Remove front door trim panel and front door trim shield. Refer to Section 01-05 .
  3. Remove front door window glass as described.
  4. Disconnect window regulator electric drive harness connector.
  5. NOTE: Use care not to enlarge sheet metal holes in the door inner panel.
    Remove two 1/4-inch rivets retaining lower bracket of front door power window regulator to inner panel. Use drift punch to knock out center pins for each rivet. Using a 1/4-inch diameter drill, drill out remainder of rivet.
  6. Remove three window regulator electric drive retaining screws from inside door to remove window regulator electric drive from front door power window regulator.
  7. Remove two window regulator retaining nuts.
  8. Remove front door power window regulator from front door (20124).
Installation
  1. Lubricate regulator mechanism with Teflon® Lubricant E7FZ-19590-A or equivalent meeting Ford specification ESB-M1C111-A.
  1. Install front door power window regulator minus motor (23208) into access hole in inner panel.
  1. Position front door power window regulator using upper studs and tabs on window regulator electric drive mounting bracket.
  1. Install rivets retaining front door power window regulator to door inner panel (1/4-20 x 1/2 inch screw and 1/4-20 nut and washer assemblies or equivalent metric fasteners may be used).
  1. Install two upper front door power window regulator retaining nuts.
  1. Install window regulator electric drive with three screws. Do not overtighten screws.
  1. Connect the window regulator electric drive harness connector.
  1. Install front door window glass.
  1. Adjust front door window glass as described.
  1. Install front door trim shield and front door trim panel. Refer to Section 01-05 snorkelbobby_38.gif
Feb 14, 2011 | 1997 Mercury Grand Marquis
Problem with the 2004 Land Rover FreeLander How to install a Freelander Window Regulator with cable loose not broken just off winder
Tools you will need:
1. Panel removal tool
2. Philips screw driver
3. 1/4 Ratchet with extension and 8 mm socket.
4. grease to lube new regulator. The first thing, is to remove the door panel:
1. Remove 2 screws securing hand rail to door.
2. Remove screw securing door handle escutcheon to door and remove the escutcheon.
3. Remove 4 screws securing pocket to door.
4. Carefully release 10 clips securing trim casing to door. (Best to use a door panel removal tool, the plastic clips break very easy)
5. Disconnect multi-plug from upper door speaker. Do the same for lower speaker
6. Remove trim panel from door.
7. Remove the plastic vapor barrier , care full not to destroy. (You may have to cut around some things such as the hand rail brackets.)
At this point you will be able to see the regulator and motor through the small holes in the door. At this stage a small flash light is very handy
to see such things as the power connector for the window motor.
1. Loosen the two bolts in the slotted holes, shown above.
2. Remove the remaining 4 bolts securing regulator assembly to door.
3. Lower glass and loosen the 2 bolts securing door glass to regulator. Then slide the channel bar forward to remove.
4. Disconnect the power from the window motor.
5. lift the window and secure in the up position ( I used Duct tape).
6. Collapse all the arms and maneuver the old regulator out the center hole in door. Assembly is basically the reverse of the removal procedures:
1. take the two screws that you partially removed out of the old regulator and install them partially install them into the new regulator.
2. Work the new regulator through the center hole.
3. Connect the power to the regulator motor.
4. Lower the window glass, take the channel that secures the glass to the regulator, insert it over the tow bolts that were loosened in step 2 above
5. Raise the window and secure.
6. Insert the 2 bolts on regulator through the keyed holes in the door and finger tighten.
7. line up the rest of the bolt holes and install the remaining two bolts in both the regulator and then tighten two bolts in step 6 above
8. install the two in the bottom channel.
9. Now is a good time to test..........
Then all that is left to install the hook up the speaker(s) and mount the door panel.
1. Position trim panel close to the door and connect door speaker(s) multi-plug(s).
2. Secure door panel to door with clips.
3. insert escutcheon to door handle and secure with screw.
5. Fit pocket to door and secure with four screws."
Dec 04, 2010 | 2004 Land Rover FreeLander
Sharp Aquos 47 inch tv. Just moved and can't find the 4 screws to the stand, where can I buy new screws or get the specs if I were to buy new ones at Home Depot? Thx
these are pretty common screws if you still have the box and everything it came wtih new then it perhaps may have the screw sizes included with it in there if not then go to a local fastener store as home depot sells them in large packages for even more money by going to the fastener store you can get multiple sizes in one shot try till you succeed and get more of the ones that fit while you return the rest i hope this helps and they are usually about an inch in 3\4 of an inch in length
Nov 19, 2010 | Sharp LC52SB55U LCD TV
Hi, thanks. I have a question regarding the portable air conditioner cvp10nc as I am preparing to purchace one. Is the air from the room being cooled recirculated exclusively through the unit and all put...
Hi kerry have tried to look for the model number as mentioned by you hwever was unable to find that on the sharp site however they do have two other models namely CVP10PC and CVP10RC for which i am providing you with the link here you can get whatever you want with regards to purchasing the airconditioner i.e brochure, case studies, governmentcompliance,installationguide, owners manual, quick,guide, spec sheet, etc. hope this helps
Thanks for using fixya
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=Brochure&category=HomeEnvironmentAirConditioners
Oct 09, 2010 | Sharp CVP10NC Air Conditioner
How to remove and install a new heater blower motor 2000 Saturn
Removal & Installation
  1. Select the following settings:
    Turn the ignition ON Select Recirc in the OFF setting Turn the ignition OFF
  2. Disconnect the negative battery cable.
  3. Remove the wiper arm assemblies.
    CAUTION A sharp edge is revealed once the weatherstrip is removed.
  4. Remove the weatherstrip at rear of the engine compartment.
  5. Remove the cowl retaining nuts.
    Fig. Remove the cowl screen assembly
  6. Remove the cowl screen assembly.
  7. Rotate the locking tabs outward to release the filter assembly.
  8. Remove the filter by lifting straight up.
    Fig. Remove the wiper module retaining bolts
  9. Remove the wiper module retaining bolts.
  10. Reposition the wiper module to the right.
  11. Remove the filter housing attachment bolts.
  12. Remove the filter housing.
  13. Remove the blower motor housing:
  14. Remove the blower motor housing screws
    Fig. Release the locking tabs and remove the fan housing
  15. Release the locking tabs and remove the fan housing
  16. Disconnect the blower motor electrical connector.
  17. Squeeze the bottom of the connector and pull downward.
  18. Remove the blower motor assembly by lifting straight out.
To install:
NOTE The fan motor assembly rib must be located into the channel in the module housing.
  1. Install the blower motor assembly into the module housing.
  2. Connect the blower motor electrical connector.
    NOTE The housing rib must fit into the slot in the HVAC module case.
  3. Install the blower motor housing. Snap the left and right clip into place
  4. Tighten the fan housing to blower motor housing screws to 9 inch lbs.(1 Nm).
    NOTE A new filter housing seal must be used whenever the filter housing is removed to prevent water from leaking into module.
  5. Remove the filter housing seal using a small flat-blade screwdriver.
  6. Install a new filter housing seal.
  7. Install the filter housing.
  8. Install the filter housing screws, and tighten the screws to 31 inch lbs.(3.5 Nm).
  9. Position the wiper module.
  10. Install the wiper module bolts, and tighten the bolts to 44 inch lbs.(5 Nm).
  11. Install the passenger compartment air filter. Notice the air flow direction indicator printed on side of the filter.
  12. Rotate the locking tabs on the filter housing inward to secure the air filter in place.
  13. Install the cowl screen.
  14. Install the cowl screen nuts, and tighten the nuts to 9 inch lbs.(1 Nm).
  15. Close filter access door.
  16. Install the weatherstrip at rear of the engine compartment.
  17. Install the wiper arm assemblies.
  18. Connect the negative battery cable.
  1. Disconnect the blower motor electrical connector.
  2. Remove the lower blower motor cover retaining screws.
    Fig. Remove the lower blower motor cover
  3. Remove the lower blower motor cover.
  4. Remove the blower motor nuts.
    NOTE Cut through the case as straight as possible because the motor cup must be replaced.
  5. In order to prevent damage to the component, do not cut any deeper than necessary to remove the motor cup.
  6. Remove the blower motor and cup from the lower case by cutting through the case between the circular ribs around the motor with a sharp utility knife.
  7. Release the blower motor retaining tab and remove the motor from the cup.
To install:
  1. Install the blower motor into the motor cup that was cut out of the lower case.
    Fig. Install the blower motor (1) into the motor cup (2) that was cut out of the lower case
  2. Install the blower motor nuts, and tighten the nuts to 21 inch lbs.(2.4 Nm).
  3. Attach the service ring to the motor cup with the screws included in the kit, and tighten the screws to 15 inch lbs.(1.8 Nm).
  4. Install the blower motor and service ring into the HVAC module using the screws included in the kit. Make certain the blower motor electrical connector is pointing rearward in the vehicle, and tighten the screws to 15 inch lbs.(1.8 Nm).
  5. Install the lower blower motor cover.
  6. Install the lower blower motor cover retaining screws, and tighten the screws to 15 inch lbs.(1.8 Nm).
  7. Connect the blower motor electrical connector.
Hope this helps (remember to rate and comment this).
Oct 04, 2010 | 2000 Saturn Ls 4dr Sedan
Where is the blower motor... i know that is the problem, but where and how do I change it. i already have the part
Blower Motor Removal & Installation Front To Remove:
NOTE: The blower motor is positioned on the passenger side of the vehicle beneath the instrument panel, and can be removed from the vehicle without removing the HVAC housing.
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Passenger side cowl trim panel
    • Carpet to access the front upper screw that secures the air inlet housing
    • Recirculation door actuator
    • Recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside
    • Blower motor wire lead connector from the blower motor resistor or power module, depending on application. Lower Air Inlet Housing chr_pacific_lwr_inlt_hsng.gif
    • One screw (from the top) that secures the lower air inlet housing to the upper air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing Blower Motor Wire Lead Grommet chr_pacific_blwr_wrg_grmmt.gif
  3. Feed the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  4. Push the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  5. Place the recirculation-air door as needed to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  6. Lightly bend the recirculation air door far enough down to remove the blower motor and wheel from the HVAC housing. Blower Motor Mounting Tabs blwr_mnting_tabs.gif
  7. Remove the blower motor and wheel from the HVAC housing. Make a note of the location of the blower motor mounting tabs.
To Install:
  1. Install or connect the following:
    • Blower motor and wheel to the lower half of the HVAC housing and line up the blower motor mounting tabs to the correct location on the HVAC housing
    • Blower motor and wheel into the HVAC housing by lightly bending the recirculation-air door far enough down
    • Three screws that secure the blower motor to the HVAC housing by positioning the recirculation-air door as needed
      1. Torque to: 17 inch lbs. (2 Nm)
    • Blower motor wire lead through the opening in the lower air inlet housing and seat the rubber grommet into the lower air inlet housing
    • Recirculation-air door pivot into the lower air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and the lower HVAC housing
    • Blower motor wire lead connector to the blower motor resistor or power module, depending on application
    • Recirculation door actuator wire lead into the routing clip located on the lower air inlet housing
    • Carpet
  2. Perform the heater-A/C control calibration procedure.
Rear To Remove:
NOTE: The rear blower motor and blower wheels are repaired only as a balanced unit. The entire blower motor and wheel assembly must be replaced if either component is fault or damaged.
    • Front center floor console cover
    • Negative battery cable Rear Blower Motor Housing chr_pacific_rear_blwr_hsng.gif
    • Body wire harness connectors from the rear blower motor power module and the rear mode door actuator
    • Body wire harness bracket from the console support bracket
    • Eight screws and the two console support brackets from the floor console base and duct assembly
    • Four screws that secure the rear blower motor housing to the floor console base and duct assembly
    • Rear blower motor housing and place it on a bench
    • Rear blower motor wire harness connector from the power module
    • Eleven retaining clips and three screws that secure the housing together
    • Two halves of the housing
    • Blower motor wire harness and grommet from the housing and remove the blower motor
To Install:
    • Rear blower motor into the housing and install the blower motor wire harness and grommet
    • Two halves of the rear blower motor housing and install the eleven retaining clips and three screws
    • Rear blower motor wire harness connector to the rear blower motor power module
    • Rear blower motor housing into the floor console
      2. Two console support brackets onto the floor console base
      3. Eight screws that secure the support brackets to the floor console base
      4. Body wire harness bracket onto the console rear support bracket
      5. Body wire harness connectors to the rear blower motor power module and the rear mode door actuator
      6. Negative battery cable
      7. Front center floor console
  2. Calibrate the A/C-heater control.
Aug 13, 2010 | 2004 Chrysler Pacifica
I am looking for an exhaust hose kit for Amcor portable air conditioner 10km-410 can you help me with this. Please let me know thanks and regards Adrian Tidd
While you may find a kit specific for your portable air conditioner, it would be far easier and faster to simply measure the diameter across the exhaust port on the back of the unit. In US measurement, it may be 4 inch or 5 inch across.
Go to a hardware store (a quaint local one or a Home Depot if you must.) They will have a kit (for clothes dryers) that will most likely include the flexible tubing and two clamps. They also will have separate/bulk flexible tubing and clamps available.
Depending on how permanent the air conditioner installation is, the same hardware store will have exhaust outlets that can go through the wall and probably fit into a partially opened window.
Please post back here with further questions or clarifications on your problem.
Good Luck!
May 08, 2009 | Heating & Cooling
Heating & Cooling Logo
433 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
