Question about Texas Instruments TI-83 Plus Calculator
My negative button wont work - Texas Instruments TI-83 Plus Calculator
  • kakima May 11, 2010
    Are you having trouble entering negative values? Are you using the subtract key instead of the change-sign key?
    The - key on the far right between the multiply and add keys is used to subtract one value from another.
    The [-] key on the bottom between the decimal point and ENTER is used to enter negative values.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
I assume from your lack of response that my earlier comment solved the problem.
Posted on Mar 05, 2010
If i jumped my yahama dirtbike and had cables. Wrong no spark or smok but now even new battery. No power wont start. Nott even clicking when push the starter. Button. Lights and horn work wont even...
I hope I read your question incorrectly, because it sounds to me like you swapped the negative & positive terminals around.. which may have burned the cables internally. If so, an Auto-electrician may be required
Nov 12, 2014 | Motorcycles
My climate control on my audi wont work i press
Have you checked your ground studs? That is where your electrical system gets it's negative side of the current.
Sep 24, 2014 | Cars & Trucks
Duracell charger wont charge..
The blinking indicator is telling you that the batteries have been inserted incorrectly. Otherwise, the charger probably no longer works
Jan 20, 2013 | Duracell AAA NiMH Battery Charger with 4...
Toyota Camry 1999 model horn does not work
new horn or relay gone most likely but make sure it is grounded good or wont work either hook battery booster cable from negative battery terminal to horn bracket if it works then clean mounting area under horn ground is bad
Dec 11, 2012 | 1998 Toyota Camry
I need to use the exponential function with a negative exponent on my TI-30XIIS. I hit 2nd then e^x button, but when i input a negative exponent I get an error. Help please!
I think what you did was use the minus sign instead of the negative sign, on that calculator, the two are not interchangeable. I purposely used the minus sign just now and also got a syntax error, but it looks like it works with the negative sign (-) located under the 3 button.
May 08, 2011 | Texas Instruments TI-30 XIIS Calculator
Is there a reset button? i put a new battery in with difficulty and it wont work. this is the casio g3011
No! there is no reset it is possible the battery is not correctly seated, check to make sure the positive and negative match what the watch indicates, because if the battery is reversed it will not work. If you still have issues take it to a watch dealer.
Jan 01, 2011 | Casio G3011 Duplex LCD Watch
2006 vw passat. car wont release hand brake. dash board says check manual. the warning lights are all on
or disconnect battery wires, positive then negative wait 2mins then reconnect negative 1st then positive, this should reset your electrics, it worked for me anyway.
Mar 21, 2010 | 2004 Volkswagen Passat
How to use negative exponents on a calculator?
Uh yes it will allow you to enter a negative exponent.... press the numbers you want then hit EXP button, then hit the +/- button and then the exponent. 60 % of the time, it works...... everytime.
Sep 20, 2009 | Texas Instruments TI-83 Plus Calculator
Engine wont start...
since have change new battery, will the motor turn over? if the engine turn over or crank, check if you have sparks, by pulling the plug out and ground it to the metal to the bike and turn the motor over and see if you getting spark, double check if you are getting fuel, two items to make the engine run, sparks and fuel. if the stater dont make any sound when you press the start button it may be faulty serenoid to the starter, check starter and starter switch. you can get a light tester and test positve and negative contact to your serenoid/starter by hold or pressing start button to see if you get power to the starter. hope that help some
Jul 16, 2009 | 2006 Suzuki RV 125 VanVan
TI 84 Windows range problem
I think you are using the minus symbol instead of the negative symbol (located below the 3).
Jul 01, 2009 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-83 Plus Calculator Logo
50 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
