Question about Kenmore Microwave Ovens
F-9 fault after 35 seconds - Kenmore Microwave Ovens
  • 572 Answers
Door lock error code
Posted on Feb 07, 2010
Hello I have a delonghi combi microwave and every time I switch it on at the mains it switches on for about a second and then trips the fuse in main fuse box
There is a short in the primary electrical circuit.
A microwave technician will need to open the housing to check.
The actual location of the fault can vary widely, ranging from water / moisture causing a short, wires burnt or touching, fan motor cooked, control board fault, a loose live connector floating, lamp holder fault, etc.
Jun 20, 2017 | DeLonghi Microwave Ovens
JEM 31 is not heating
Sounds like you have a bad transformer. Magnatron should check less than 1 ohm (with wires unplugged). Diode should check resistance one way and open the other. Must have a proper diode checker for this. Check resistance on the capacitor (make sure it is discharged first). Resistance should come up then back to open, reverse and same thing if cap. is good. Check resistance on transformer windings.
Nov 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs for 5 seconds then shuts down displaying F9 HELP
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad
Oct 19, 2014 | LG Microwave Ovens
E7 fault on bosch oven/ microwave
this means a control board problem . However follow this steps: use the common sense and carefully. God bless you
Enter the Service Test Mode as follows:
1. Open door.
2. Press DELETE.
3. Press pads 1, 3, 5, 7.
4. Close door.
5. Press DELETE within 15 seconds (Pressing RESET at any time will cancel the Service Test)
Sep 16, 2012 | Microwave Ovens
T783sf sparks from turntable coupling
No it is not safe to use, the windings of the motor are shorting against the coupling, solution! the turntable motor must be replaced in order to resolve the situation.
Jun 19, 2012 | Panasonic NN-T783SF 1350 Watts Microwave...
Turns off after 2 to 4 seconds
Hi, am afraid it sounds like the power control module is bad. The new module retails for about $155, APP has it for $129. You can try replacing the module, or purchase a new microwave. Over the range microwaves start at about $280-$350 and can go up to $1000 depending on brand/features. Microwave installation is typically $35-$50.
Mar 23, 2011 | Maytag MMV4205 Microwave Oven
I have a GE SpacemakerXL Microwave Oven Model JVM1340. The pad is unresponmsive. When pluged in I get a line of eights and then get the message F 3.
Thanks for the opportunity to help! To see if this fault can be cleared, do the following:
  1. If your unit is plugged into an *outlet (most times, this is located over your microwave in small cupboards).
  2. If it is, unplug the cord and wait about 30 seconds.
  3. Plug your microwave back in and see if the panel now works.
  4. Go through all the initial setups such as setting the time.
  5. If the fault does not reappear, then you are good to go. If the fault reappears, you will have to call service or replace the product.
*If your unit is hardwired, find the circuit breaker and turn it off for 30 seconds, then turn the power back on.
If you find my assistance helpful, please rate my service. Thanks for using FixYa.com
Jan 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 1994 Pannasonic Microwave Model T994sf . The microwave does not heat and somtimes turns off after 20 - 35 seconds. I chnged the fuse and it still does not heat up. Can you help?
When the cost to repair exceeds the cost to replace, it isn't worth repairing. That Microwave is > 14 years old and chances are the Magnetron tube or the filamant power supply is failing after all the use. If I were you, I would consider buying another Microwave to replace it.. Hope that helps..
Sep 01, 2008 | Panasonic Microwave Ovens
Microwave works for 30 seconds and then turns off
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 23, 2008 | Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
