Question about Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side By Side Refrigerator, White (GS 5SHGXKQ, GS-5SHGXKQ)
How can I stop the drain line in the back of the freezer (bottom of the condenser) from freezing up and causing water to fill up the bottom and freeze?
  • 572 Answers
Cleaning it. something keeps water from running down wich freezes in the hose
Posted on Feb 07, 2010
Leaking water on floor
Remove contents from bottom of freezer. Turn ref/freezer off. Use the handle end of a screwdriver and carefully break up the ice build up from the bottom of the freezer. Find the condensate drain and remove ice build up. Find the condensate drain and remove ice or any kind of restriction from the drain line.
Or you can turn the refrigerator off for a day , mop up the water and blow out the condensate drain
Jan 18, 2016 | Maytag Refrigerators
I need to stop water from getting on the floor of the freezer?
If your refrigerator is frost-free, water may not be draining into the evaporator pan underneath. The drain tube may be clogged.
Dec 18, 2014 | Refrigerators
How do i stop water ciming out of the freezer
check your condensation defrost run off line for blockage. may have to remove the back interior panel of the freezer to access the water catch pan. debris blocking the drain or the defrost line will cause overflow into fridge interior
Jul 03, 2014 | Frigidaire Ovens
Condensate drain inside of freezer compartment keeps filling up and freezing and then overflows to bottom of freezer compartment and freezes. Have made sure drain line is clear. Problem occurs about every...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 22, 2011 | Kenmore Side by Side Refrigerator
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice builds up in bottom of freeze side by side
This is usually a plugged drain trough. Every time your refer defrosts itself, the melted frost drips off the evaporator behind the wall of your freezer and drains into a drain trough, through a hole and into a drain tube that ends above a condensate pan where the heat of the compressor-condensor evaporates the water. Food gets into this drain line and plugs up your line, causing it to freeze the melted water into a slab of ice that eventually drips onto your floor. Most units you have to remove the freezer back panel inside the freezer to get to this, although some models you can see the drain trough without removing the panel. You can use hot water to clear this. Flush it out until you hear water pouring into you condensate pan. I use a garden pump up sprayer to shoot pressurized hot water through the drain line to make sure it is cleared out. Needless to say dont use this if you have had any poisonous chemicals in your sprayer. Good Luck, Appliance Specialists
Dec 14, 2009 | Washing Machines
Water running out bottom of freezer
That's exactly what it it. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 27, 2009 | Kenmore 53642 / 53644 Side by Side...
I have a jenn air JCD2389GES. Every day I'm getting puddles of water underneath the the unit. Our ice maker is turned off (broken for the third time)but the water line is still open to dispense water. We...
The condensate drain may not be draining into the pan under the fridge or it may have a leak or could even be not connected to the condensate pan in the evaporator.
Another possibility is that your condenser might be dirty or plugged causing the suction line going to the compressor to freeze up and then thaw leaving puddles under the fridge. Clean the condenser (the coil under or behind the fridge) and it should stop.
Over stocking the freezer will cause this as well. If you cover the air return in the freezer the evaporator will freeze up and the suction line will freeze back to the compressor.
Jul 09, 2009 | Jenn-Air JCD2389G Side by Side...
Water pooling and freezing in bottom of freezer. I've shut the valve so no water is going to the ice maker but water still collects. I can't figure where the water is coming from. Can you help? Thanks!
Sounds like the drain from the freezer evaporator coil is plugged causing the condensate to overflow and fill the bottom of the freezer then refreeze. Most freezers have a drain line from the evaporator to the bottom of the refrigerator leading to a collection pan to allow evaporation of the condensate. You may be able to access the evap condensate pan by removing the rear panel of the freezer. I can not say for sure without the specific model of the unit in question.
Jun 23, 2009 | LG LFC25760 French Door Refrigerator
Ice is forming at the bottom of the freezer and freezing the bottom draw shut. it doesn't appear to be leaking and the door shuts properly. it's supposed to be a frost free freezer....
Causes:
High humidity in the immediate area causing condensation to freeze at the door opening
A frozen defrost drain line not allowing water to drain off when the unit is in defrost
A bad door gasket causing an air leak
Some freezers have a heated perimeter to reduce condensation. If the stop working, moisture can accumulate arounf the door perimeter and freeze.
Leaving the door open too long or something obstructing the door
Mar 28, 2009 | Freezers
Refrigerators Logo
88 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
