Question about Motorola Mobility RAZR V3
Does my phone have to fully charge before i can use it again?
I popped out my battery and when i put it back in my phone wouldnt turn on. I plugged in the charger and now it says its charging but I cant use it. Does it have to fully charge before i can use it again?
    President:
  • 949 Answers
No, try and remove the battery again. wait a few minutes.
Now replace the battery, plug the phone in, now press and hold the call button which is the on button for 10 seconds and see if it powers up.
Any more questions just ask.
Posted on Feb 07, 2010
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
My huawei ascend m860 wont charge. when i plug in the charger nothing happens. it was working fine yesterday and last night it wouldnt charge up. today i bought a new phone charger and it still wouldnt...
This happened to me too, you have to take your phone back to who you bought it from so they can repair it. Its the chip inside the phone that is bad. Not the charger.
Dec 31, 2010 | Cell Phones
My C903 phone stoppped orking and wouldn't turn on
possible software fault, try using sony ericsson update which you will find on sony ericsson website
Apr 01, 2010 | Sony Ericsson C903 Facebook - black Menu...
The phone is only 4 months old and it just died. It will not turn on. have charged it.....no signs of life. Taken the battery out and put it back in.....still dead. It was fully charged when it died.
before this thing happen, is there any sign or pop message coming out your phone, "memory full, delete some data"
try to remove your memory card first then try to ope it again
Nov 02, 2009 | Motorola Mobility Rival A455 Cell Phone
My fully charged 3g Iphone in the Bose Sounddock it keeps poppin
Try putting your iPhone into "Airplaine" mode. It's possible that the radio frequencies from your phone are interfearing with the speakers in your sound dock.
Oct 06, 2009 | Apple Bose SoundDock Series II Digital...
Screen shows battery with a red line through it
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Feb 16, 2009 | RIM BlackBerry 7130c Cell Phone
Battery problems
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Jan 04, 2009 | Nokia 7270
My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Mar 21, 2008 | LG enV VX9900 Cellular Phone
Wont turn on
Please check the charger connector for dirt, if possible take an old toothbrush and clean with alchohol, let it dry and refix everything. should work.
Jul 23, 2007 | Sony Ericsson K610i Cellular Phone
Wont turn on
replace cell battery with new one
Jan 25, 2007 | Samsung SGH-e317
Motorola Mobility RAZR V3 Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
