Question about Dryers
Dryer element is not drying clothes like it use
Maytag Dryer Model DE409 Series 01, Serial # 329907EE: Dryer element is not drying clothes like it use to. Does anyone no where I can purchase the replacement part, and how hard is it to repair, how much time it takes, etc.. and the costs. Can I even do this repair myself?
  • 572 Answers
If it takes too long check your vent
Posted on Feb 07, 2010
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
Why would my dryer not be heating?
Most likely the heating element. But look for blockages that could cause safety's to trip before purchasing expensive heating elements is what I always say. To prevent fires dryers have a series of limits wired into the harness to shut down the element in case the dryer over heats. Maytag blowers are made of plastic and often are a cause of overheating. The clothes take much longer to dry if a blower wheel is to blame, so check that too. themobilian_94.jpgthemobilian_95.jpgthemobilian_96.jpgthemobilian_97.jpgGive me your model number and I will be more specific. Not all maytags are the same.
Nov 10, 2010 | Maytag Dryers
Our dryer stopped heating up and will not dry clothes
tif it is most likley the element has gone bad they usually cost about 45 dollars and if you can find a friend to help you replace it its not that hard best bet is to call a used appliance store they usually have them new and in stock do not try going to the manufacture they will charge you double for the same exact part
Apr 12, 2010 | Maytag SDE3606A Electric Dryer
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
My Maytag Model DE410, Series 01, Serial 197938 - won't dry I think the heating element is out. The clothes aren't dry at all - it is on normal dry, but the clothes come out like it's on air dry - not...
Heating element is bad! I have the same exact problem. I Just finished pulling the heater out 20 minutes ago. I ohmed it before I pulled it(showed to be bad) and after I pulled it I found the break in the heating element.
Directions for a DIY!
Turn Off Breaker and Unplug Dryer! Pull two screws near bottom in front. Pull bottom of panel out and the top will pop out. 5x16 inch diameter tube inside on the bottom right is the heater assembley pull the three screws in front and one in back that hold the assembley inside dryer. Unwire two wires feeding assembley. Your done! Only takes about 15 Minutes, Tops!
Lowes Warehouse carrys it. 1-800-476-8160 Part# Y313538 Price $51.71 Ship $7.99 Open 8am to Midnight
Hope you can do this yourself and save yourself some money! Good Luck!
Industrial Maint. Man
Sep 01, 2009 | Maytag Dryers
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
Maytag haevy duty stack washer dryer unit model # SE1000 series 06
I hope you got this fixed by now but if not I'll put in my 2 cents.. I assume that your dryer is electric and not gas. Assuming that is true then you probably have an open heater element.. similar to this used in electric stoves... There may also be other components that could have failed and in so doing, disabled power to that element. Could be a contactor or temp switch/thermistor.. Hope this helps and that you've already solved the problem...
Jul 05, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag dryer thermostat
Not 100% about this model, but the stat is located next to the fan.
Remove the front cover - insert a flat blade between the lid and front panel approx 4" in from each side to release the clips, lift the lid, remove the front panel (2 screws) fan and stat at the bottom, rest is straight forward.
May 04, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
