Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Blue shadow runs across top and bottom of screen
2 Suggested Answers
  • 4234 Answers
SOURCE: Screen shadowing with colored lines
This is most likely a convergence problemand can easily be fixed. If you can solder you can repair this yourself. First try resoldering the pins on the convergence ICs. If that failes to resolve the problem, replace the ICs. THese are large black Ics attached to a heatsink and may be marked STKxxx.
Keep us posted.
Dan
Posted on Jun 27, 2008
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
My mitsubshi vs 50609 has blue shadows how can this be fixed
you might need to adjust Blue drive on screen control to Blue tube.you have a focus and screen control box 3on top 3 on bottom of it 3 on top adjust focus to each tube R/G/B and 3 on bottom adjust screen drives.
Nov 12, 2009 | Televison & Video
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
May 05, 2009 | Sony KDF-50E2000 50" HDTV
Shadow Lines Across Screen on Dell P1130 CRT Monitor
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
Jan 29, 2009 | Dell P1130 21" CRT Monitor
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Blue shadow across my screen
Go into the convergence function from the menu and see if it works. If it does not then the convergence board has a problem. JVC still sells the part.
Jan 20, 2008 | JVC AV-56WP74 56" Rear Projection...
Blue shadow
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 25, 2007 | Toshiba 53AX61 53" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
