Question about Bosch Cooktops
Hot water goes cold
Hydropower 16H external instantanious hot water unit. when I have a shower the hot water stops flowing when the cold water tap is used, you have to be lucky for the mix rate to work right. If you get it wrong ( which inadvertently will happen) you have to turn the hot off, then on again befor it will begin to heat up again.
Can you help in explaning this problem and solution for me PLEASE
Ray
Did you find a solution because I am experiencing the same problem, but only since i change to a new shower head?
Regards
Christine
Posted on Feb 17, 2010
Neff T22S46NOAU gas cooktop. Gas to burners on one side only reduced. Flame barely visible. What is the problem. Can I fix it myself?
take off the flame spreaders and soak them overnight in kitchen detergent and water. Change the water and boil it for 10 minutes. Put under the cold tap and them scrub with a pot brush into all of the holes. Rinse, dry and replace.
If that doesn't work, you need a registered gas engineer.
Jun 11, 2017 | Neff Cooktops
G E Select ice maker has stopped making ice
First, check the filter and make sure it isn't clogged. Second, check the water line and more importantly, the valve that feeds the water to the fridge. It should be 1/4'' line and usually has a saddle valve installed off another larger cold water line. Saddle valves have a tendency to rust and clog. these are simple fixes, generally. IF all these check out OK, Check the water valve inside of the fridge, where water line comes in..Hope this solves your problem.Good luck DW
May 11, 2014 | GE Ribbon Module for Select-Top Modular...
Viking stove burners blow out and relight if you tap gas valve. Hot surface igniters glowing but burner still loses flame and then make gushing noise. Is it the valve or the worn igniters?
Which model do you have? Sound s light your unit re-ignites if flame goes out, if so, I would clean the burner. This means with a old toothbrush remove everything baked or burnt on. Assure your small orifice with in the burner is clean and you can see the port (hole in the center). Most of the time I have found clogged burners, or the burner cap (selected models) were installed incorrectly to cause this issue. Give that a shot and get back to me if you have more to add or just more questions.
Thanks
Oct 17, 2013 | Cooktops
Whirpool cook top surface light countiune on even surface are cold
How long does it take for the light to finally go off?or does the light ever go off when a cooktop decrease in tempreture has to reach the tempreture set by the factory for that light to go off. Sounds like a thermal switch which controls the hot surface light is stuck closed If this is a new unit, I'd return it. If not, I would check the switche(s) for the hot surface light -- when the unit is cold, unplug one wire going to the thermal switch and check it for electrical continuity. If you get current from a multi-meter through the switch, replace it -- it's not opening when it cools down.If you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 12, 2010 | Whirlpool RCC3024 Electric Cooktop
We have new house and have cold air coming from Jenn-air vent. What can be done to stop this? We had a Jenn-air in our previous home and did not have this trouble
Most stove vents have a diverter plate which prevents air from coming in. When the fan is turned on, this diverter is opened by the air flow and allows the air to flow through. It sounds like this plate is either stuck or was not installed when the ventilation duct was installed.
Oct 16, 2009 | Jenn-Air JED8430 Electric Cooktop
Just installed an electric cooktop and the Hot Surface indicator light has been on since installation. How do we fix this?
Sounds like a thermal switch which controls the hot surface light is stuck closed.
Charlie
Aug 20, 2009 | Whirlpool Cooktops
Viking 30" gas professional series cooktop sparking problem
And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
Thanks
Kindly rate the answer
Kevin
Jul 06, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Simmer is too hot
one way is the orfice that goes inside the burner.some have a little screwin the knob shaft to ajust.if no screw its the orficc.theres a tech sheet that will give you more detail about that on that stove.bottem drawer area or back.also so ranges have orfices on them in the back also.God bless,tom
Jan 01, 2009 | GE 36 in. Profile JGP962 Gas Cooktop
Automatic Eletric Ignition stopped working
It's is normal for the ignitors not to work when wet, once they dry they should work. The best thing is to check the electric sending unit, they are a small white kind of square that goes on the switch, just lift the knobs and take the cover of the switches and you should see the sending units righ on the rod that hold the knobs, they have to small wires attached to them, It seems to me that thats were your problem is.
Do you hear the click clik when you put the knob on LITE??
May 19, 2008 | GE 30 in. JGP336 Gas Cooktop
Electronic ignition
Alien, one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad. Catriver...post back.
Sep 23, 2006 | Jenn-Air JGC9430 Gas Cooktop
Cooktops Logo
835 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
Narinder Chhina
Narinder Chhina
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
