Question about Samsung HLR5067WX 50" Rear Projection HDTV
Intermittant picture & audio on 50" SAMSUNG DLP TV
My 50" Samsung DLP TV picture freezes then turns off and on intermittantly. udio is also affected. This problem occurs with Cable TV, X-Box 360 and Off-the-Air signals. I replaced the lamp yesterday and the problem is still there. I'm pretty savey with electronics but I don't want to start taking the unit apart to start further troubleshooting if there's a simple fix, or perhaps someone with more experience recommends looking for a particular issue or can steer me in some direction. Thanks / Joe from Chesapeake, VA
SOURCE: Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
Posted on May 08, 2008
  • 17 Answers
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Posted on Jul 11, 2009
  • 4090 Answers
SOURCE: Remote Code Samsung 50" DLP HL-R5067W
022 036 043 159 160 170 175 212 215 702 713 706
Posted on Aug 01, 2009
SOURCE: Smasung 50 Green Screen
I had a 50" DLP sampson with the green screen problem plus it has a power off problem; meaning the TV shuts off for about 10 seconds then turns back on when watching Hd TV it got to be a problem when if happend about ever half hour. The analog TV stations are the only green screen. You had to unplug TV to get rid of green for short time.
If you feel the back cover of theTV, the cover is hot to the touch, so hot in places to make you **** your hand back from the heat.
I removed the lower back section ( had to unplug all cables from back cover,Don''t forget the power cable) I used my shop vac placed the hose on blow outlet and blew out all the dust inside the set. (DON"T put hose to close to TV's componits!) Next I removed TV's LOWER back cover, found vent in back for the TV"s fan (over the heat sink), marked the back vent then I went to local Electronics store.
I purchased one 115 volt fan , one cord that pluged into fan and other end into eletricial outlet. Locating center of TV fan on TV's back cover
find best location to mount fan. ( I check fan before mounting by plugging it in to wall outlet to find out air flow direction) I wanted the air flow pulling air out of TV. I mounted my fan on outside of TV's cover left and up from THE TV"s FAN CENTER.
Remount TV's cover with fan. Plug in all your cables, plug in power and fan. turn on TV. After I done above proseager After 8 hours of tv bring on no green screens, no power shut down. The back pannel of TV is cold to the touch except the vent for the projecter lamp.
The Fan I used is a Orion coolong Fan (Knight Eletronics) Part number OA92AP-11-1TB total cost: Fan and cord, nuts, washers and & bolts Under $25.00. Not bad even if TV just last another few months
Posted on Mar 20, 2010
  • 150 Answers
SOURCE: Samsung HLP5063WX/XAA 50" DLP
Here is a site for ColorWheel replacement, which is what you need to do if you hear that screeching or fan running noise coming from your TV. Sometimes the wheel just explodes which gives you no picture.
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Posted on Jul 13, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Samsung DLP TV shuts off
sounds like your power supply is going south...check the voltage coming out of the wall first
Feb 25, 2008 | Samsung DLP HL-P5663W 56" TV
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
Samsung DLP picture keeps freezing
The problem is either the color wheel or dmd board. Both parts are expensive so I would recommend contacting a Samsung authorized repair center. You can call 1-800-samsung or go to samsung-usa.com to find a service provider.
Jul 13, 2010 | Samsung Televison & Video
50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Feb 04, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
A 42 or 46'' Samsung picture shuts off but still has sound
Remove all video inputs including hdmi if problem goes away. Determine what input is suspect and call smasung for a firmware upgrade. HDMI casued intermittant behavior with this series, but was sometimes seen on component video.
Jun 29, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
Henry  Thomas
Henry Thomas
