Question about Magellan MAESTRO 3100 98083401 GPS Device
Cord will not light up or charge magellan - Magellan MAESTRO 3100 98083401 GPS Device
    President:
  • 1,111 Answers
If the light does not com one on the car charger, try another charger if you have one, or a home charge if you have one of those...this model also has a common problem if you have a good charger.
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Posted on Feb 07, 2010
  • Ben Dover Feb 17, 2010
    do you still need help
I cannot get my Magellan RoadMate 1700 to charge with AC power cord? What can I do?
Check the LED indicator on the charger make sure its lit. Try a different power cord.
May 23, 2017 | Magellan GPS
Device will not power on
I found a Magellan Roadmate in the dumpster when I was dumping the trash off my truck.They were even so kind to leave the charging cord.I figured out that the charging cord wasn't connecting to the unit when plugged in.It took 20 minutes to figure out how to pop the case open(retainer tabs on all sides in addition to the screws).Once opened up,it took 5 minutes to repair the solder connections from the power socket to he circuit board.Works like new!
May 31, 2012 | Magellan Roadmate 2035 4370 2036 4040...
Our magellan keeps turning off. the plug seem loose. could it be the cord or is it the battery and can it be changed
Check your power cord. You may be losing power at the plug. When plugged in it may be losing contact with the recepticle. The power indicator light initially comes on but, breaks contact and therefore stops charging the unit. If this is the case you can sometimes plug into an adapter and get a tighter fit.
Apr 25, 2011 | Magellan Roadmate 1200 Car GPS Receiver
My magellan 4040 will not hold a charge. I thought it was the cord and bought a universal cord for the car and it still will not hold the charge. Help
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below (magellan 3000.3050 and the 6000 take about 10-15 seconds to start from the off position)
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Standing Member of G.O.T.
Sep 04, 2010 | Magellan Maestro 4040 GPS Receiver
Power cord is not charging unit. There seems to be a loose fit in the socket of the Magellan Maestro 4000. Is the problem with the charger cord or the Maestro 4000 socket?
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | Magellan Maestro 4000 GPS
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
The internal connection where the cord that charges the gps system will noe hold the cord connection and thus will not charge the systwm.
You might have the wrong charging cord which is why it might not fit or stay in for it to charge. All you need is to buy the right-sized cord.
Oct 22, 2008 | Magellan GPS
Start-up instructions
I'm confused? Did you plug in the charger or the computer adapter. It needs to charge using the power cord. The USB cord will likely not charge this unit.
Aug 19, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Magellan MAESTRO 3100 98083401 GPS Device Logo
199 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
