Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
The television was on and it went dean. I tried to ture it on with the power button on the tv but that did not work. Is there a fuse in the TV that can be rep[laced?
  • 201 Answers
Try the easy stuff first. Make sure the AC cord is plugged tight into the tv (the cord is removable and sometimes they come loose. Make sure there is power at that outlet by plugging something else into it to test. If that doesn't fixit there is a fuse on the power supply. Unplug tv and remove cover to check it. Most fuses are clear glass so you can tell if the wire inside popped or not. If it did you might get lucky and it just needs replacing. Always replace with exact same size and rated fuse. If it didn't pop the power supply may have failed. This link
Power supply will take you to an online parts store. Power supply is the #1 suspect. The main pcb (motherboard) would be #2. Good luck.
Posted on Feb 07, 2010
Hi? My Sony Projection T.V model KP-FX432M91 is taking time to power on and once it has powered on it work fine.what might be the problem?
Power button may need to be replaced. Try turning on via remote.
Some TVs need to warm up before coming on. Hitting the power button several times may in all actuality be Turing it off and on.
Sep 20, 2016 | Sony Kp-Fx432M91 43" Projection Wega...
Toshiba tv no power
I have never heard of or seen a "power down button". Unplugging the TV and holding the power button for a minute or so sometimes will do a hard reset on the TV, is that what you seen?.
On your problem, chances are there was a spike that came down the power line when your power went out and it took out at a minimum the main fuse in the TV, you can remove the back and replace that fuse on the power board and see if it comes on or blows the fuse again, if it blows then look for a bad rectifier or shorted FET transistor in the hot section.
Nov 26, 2017 | Toshiba 32AV502R LCD TV
Tried turing on but just keep clicking.. no picture or sound
Tries tv unplug,replug it back about an hour later,by letting the tv resetting itself back to the factory setting.The tv now should be work again.If it have the same result.Mean the power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries website like Ebay.com to buy a refurbish power supply board for the replacement.
Feb 01, 2011 | Philips 50PFP5332D 50 in. Plasma...
Tv not getting no power at all
Check the fuse on theit my be blown if it is check the diodes around it they may be shorted also check the cap also where the power come into the board
Jan 28, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My 52 inch sanyo tv just went blank can't get it
Try unplugging it for 8 hours for reset. If this doesn't work, then fuse or power supply is faulty.
Sep 04, 2009 | Televison & Video
Can't get power on tv
Is the LED light on? If not then the Power supply may be bad. Try to unplug the TV and then plug back in. There is a fuse near the AC input. Check the fuse If the fuse is OK then the Power supply has gone bad.
Apr 01, 2009 | V, Inc. Vizio P50HD Plasma Television
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
Reset button
No reset button for a long time on any brand of tv.....
Check horiz output transistor,fuses and power supply
components........................T.
Dec 21, 2007 | Symphonic ST419E TV
No power up on Polaroid Tv Model TLA-01511C
When your VGA goes down, try unplugging your tv, then starting it up again. It works for me
Oct 05, 2007 | Televison & Video
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
48 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
