Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80, memory card jammed
For some reason I cannot eject the SD card, There is not a raised part of the card visible
  • Anonymous Feb 23, 2009
    SD card will not eject. HELP!
Push the top of it and it will pop right out!
Posted on Jul 14, 2008
    Problem Solver:
  • 18 Answers
Can it be pushed into the slot any farther?
Posted on Feb 21, 2008
Upgrade firmware for Nikon D80
Confirming the firmware version:
  1. Turn on the D80
  2. Press the MENU button and select Firmware Version from the setup menu. The camera's firmware version will be displayed.
  3. Turn off the D80
Basic Upgrade instructions: for detailed instructions, see pdf files below.
  1. Download and expand the firmware files
  2. Format an approved SD (Secure Digital) memory card in the camera
  3. Connect Camera to computer (in MSC USB mode) or use a SD Card Reader
  4. Copy to the top level of the card the downloaded "A firmware" file
  5. Disconnect camera from computer
  6. Update the firmware from the "Setup" menu
  7. Follow the camera's on-screen menus
  8. Repeat steps 2 through 7 using the "B Firmware"
  9. Re-format Card
D80 1 11 firmware upgrade Nikon Knowledgebase
Apr 03, 2014 | Nikon Cameras
I unplugged my Nikon D80 from the computer without clicking the safe to eject drive button and now it seems to be stuck in PC mode!
Try resetting the camera by removing the battery for 20 mins, then replace the battery and go to the Menu setting and set the Date and time.
May 27, 2012 | Nikon D80 Digital Camera with 18-55mm Lens
My Nikon d80 shows the msg as card is locked,how ever i tried to solve the problem by sliding it to write position.Can someone can help me rite now?
Here is a diagram to show the correct position of the switch.
Good big picture and it doesn't matter that it has Canon written on the SD card in the picture the SD card is interchangeable between the two makes.
Now one other thing that may also be the problem is that the SD card needs to be formatted to the camera. Formatting should be done on new memory cards and after you have downloaded pictures to the computer. That's format not delete, delete leaves a mess on the card Formatting cleans the card and provides proper communications between the camera and the memory card
Jan 21, 2011 | Nikon D80 Digital Camera with 18-135mm...
How to transfer data from the internal memory of a nikon d80 to an sd card?
The Nikon D80 does not have any internal memory.
Jun 12, 2010 | Cameras
My computer is not reading the memory card. Nikon D80
If you are using a 4GB or higher SD card, some computers cannot read it directly from their in-built SD reader. Buy an external card reader and plug it in. Your computer should now be able to read cards 4GB and larger
Oct 07, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have a Nikon D80. A few months ago, the SD card would not stay in the slot, then for no reason it started working normally agan. Now it won't stay in again. It doesn't catch when you push it in, it just...
the sd card slot is designed in such a way that when you push your card inside the slot till the deepest part and when yout leave it, it fits into the slot. if you want to take the card out you have to push the card again till the deep and leave to get it out.(just like a spring aided trap). i dont think that your slot is damaged.may be you are unsure how to insert the card in the slot. if you still find problems, please write back.
Jul 21, 2009 | Nikon D80 Digital Camera
Nikon d80 can't take pictures
Be sure you don't have the SD card loked (look at the tab on the SD card itself). You may be seeing CHA or something similar in the viewfiner too.
Apr 24, 2009 | Nikon D80 Body Only Digital Camera
Problem in reading memory cards of NIKON D80
Some notebooks cannot read SD capacities of 4GB and above. The workaround is to use an external SD card reader.
NOTE: Please rate our help to keep this free service online
Apr 22, 2009 | Nikon Coolpix 5700 Digital Camera
Nikon D80 no picture number in LED & menu not working
Format the SD cards with the camera. You might have to do a software upgrade on the camera since the Kodak card files are different than Nikons.
Mar 29, 2017 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 SD Card slot problem
Is it slightly thicker on the contact end, Or is something stuck on the flat corner? try getting a needle and picking out any plastic that could be stuck there. Is the card under warranty
Sep 09, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
314 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
