Question about Philips DVD750VR DVD Player/VCR
DVD/VCR combo has trouble showing vcr tapes on tv screen
I have a Philips DVD/VCR combo. It will play the DVD's and show them on the TV screen. However, when I switch to VCR, it plays the tapes, but it won't show up on the TV. Any ideas?
pishta68
  • 593 Answers
SOURCE: CONNECTING DVD/VCR TO CABLE BOX & TV ETC
If using 3 color RCA (r/w/y) the red and white is audio and should go into your stereo under video or AUX. The yellow is the only video cable you need, that should go to your TV aux in or video1 or video2. You can also put all 3 colors into the tv and then run another red/white OUT to the stereo AUX in and have stereo sound for whatever you are watching.
Posted on Feb 28, 2008
WhIzAtIt
  • 136 Answers
SOURCE: Philips MRV700VR DVD Recorder / VCR Combo
Crack the top open and look inside for any foreign matter. Usually the cause is debris in the IR path that detects start and end of tape or the loading mechanisim is faulty.
Posted on Sep 24, 2008
salsaurbana
  • 56 Answers
SOURCE: HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Posted on Nov 19, 2008
SOURCE: I can't play any VCR tapes or DVD's in my Magnavox. Shows E1
Hi All, I realize this post may be a bit late for some but I just bought this unit myself on 12-22-08. After reading the pdf manual I downloaded from an earlier post the description of "E1" and "E2" is on page 20 and more details are on pages 35 & 36.
"E1" is the display indicator the unit is looking for a External input signal or Line Mode. "E1" External input on the rear, "E2" External input on the front. No signal present so the unit shuts off.
I suggest changing/setting your record channel or source before starting any record mode steps. Hope this helps.
Sybrsound
Posted on Dec 23, 2008
opherator
  • 44 Answers
SOURCE: TV DVD VCR combo eats tapes and now won't eject DVD's
Its shot, time to get a new one. dvd players are now only $20
do you have a newer lcd tv. Id say look into getting an upconverter,itll play your dvds at 1080 :) better picture.
Posted on Feb 27, 2009
The VCR is playing the tape but the picture won't show up on the TV
Is there a video output from the vcr? Have you tried the video on another tv set? If other tv set also does not work then the issue is with the vcr output circuits.
Nov 21, 2015 | GoVideo Go Video DVD/VCR Combo
How do I get the VCR to play on the tv? It's a Sanyo DVW-7100 DVDPlayer/VCR Combo. The DVD will play but the VCR won't show up on the TV.
This maybe too simplistic but are you sure you have the right command buttons toggled try to set the player to VCR and not dvd.
Set the player to VCR with a tape in it and press play. I hope this works for you
Sep 29, 2010 | Sanyo DVW-5000 DVD Player/VCR
Blue screen
At least a couple of possibilities, check the yellow video cable that runs from the VCR to the TV, is it plugged into the side of the combo unit that says vcr?
Is your TV on the right source? You could have plugged the audio into say AV2 and the video into AV1, causing a mismatch. Make sure the yellow, red, and white are all plugged into one input section on the TV (AV1, AV2, Video 1, Video 2, etc).
Dec 09, 2008 | Philips MRV700VR DVD Recorder/VCR
Vcr will not record
THE CABLE OR ANTENA NEED TO SCREW INTO THE INPUT OF YOUR UNIT THEN A SMALL WIRE OUT TO THE TV FROM YOUR UNIT PUSH RECORD WHEN SHOW IS ON TV !SO ITS CABLE INTO VCR INPUT THEN CABLE FROM OUTPUT OF VCR TO TV ....TV ON CHANNEL 3 AND VCR UNIT ON CHANNEL 3
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
My tv shows are taping in black and white
if you have the dvd's s-video plugged in and also something plugged into the yellow video input this will happen , does the piture on the tv show black and white?
otherwise the vcr head is dirty and needs to be cleaned
please rate a fixya and I'll be happy to even assist you further
electech
Nov 07, 2008 | Samsung DVD-V2000 DVD Player/VCR
Magnavox MWD 2206A vcr/dvd combo
you probable have a dirty video head...you can try a tape head cleaner tape/// they sometimes work.... if not you need to get to the video head and clean it with a liquid cleaning solution---
one of your tapes may have a bad spot on it causing the problem...if you clean it and use the same bad tape again you can cause the same problem again
Jul 25, 2008 | Philips Magnavox 20MC4304 20 in....
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
VCR Tape will not play, it keeps ejecting
I have a similar problem. It takes 3 or 4 times to get my Sony VCR to accept a tape. Once it does, everything is fine, until I turn it off. Next day, same trouble. I tried several tapes and brand new tapes. No difference. I have opened the cabinet and used alcohol to clean various stuff, no change.
Feb 02, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
Philips DVD750VR DVD Player/VCR Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
