Question about Carrier Heating & Cooling
Heat pump doent kick back on after defrost-blows 5amp breaker
I have a Carrier Heat Pump System. It’s about 5 years old and has functioned OK until this Christmas Eve. One problem is the condensing unit is not kicking back on after it goes into defrost mode. I found a 5AMP fuse blown in the attic unit and once replaced it functioned. At least for a day or two (I’m guessing until it went into defrost mode again). My thermostat blinks “heat on” but will not communicate to turn the heat pump back on (regardless of time-frame). The “on” fan will kick on if done at the thermostat but not “auto” (in heat mode). When I go to “Em Heat” it kicks on immediately & works as intended. I’ve learned it heats better than nothing. I had a few local Heating & Air guys come out to service/fix ect. One of the two companies went to get parts on the 3rd of January…..guess he’s not coming back. 2nd guy was here 30 min, pumped $600 of Freon in the system and was gone before I could get home from work (30 min away). He also found and fixed something loose up close to the breaker that has blown a few times. It worked a week (warmer weather) then more of the same. When I went up to change the fuse in the attic it was not blown. When I turned the breaker back on located on the attic unit it starting working (had left the thermostat set to “heat”). Only thing I can come up with is loose wires or circuit board??? Later that night I had to go back to Em. Heat and can’t seem to rattle it back to life. Can you damage by overcharging the system? Tech told me no leaks in system-if installed correctly 5 years ago is that possible? Wow……………….that ended up more like a novel!?! Any direction would be appreciated…….its cold!
    Guru:
  • 415 Answers
If you continue to blow the 5 amp fuse, you have a "short" in the control circuit. It could be the reversing valve solenoid coil (very rare) or it could be in the wiring. It is possible that you have a wire with cut or melted insulation that is causing the low voltage short. If this is happening only during the defrost cycle, then you want to check the wires going from your defrost board to your reversing valve solenoid coil. Also check the wires going from the defrost board to the defrost thermostat. Often, some electrical tape and some wire ties to pull the wires away from the area that damaged the insulation is the only thing that is needed to correct this problem. I hope this helps. Good Luck!
As far as the refrigerant is concerned. Yes, it is possible to overcharge a system. It would have to leak out, but it is not uncommon to charge a system that has 5 years and perform a quick check for leaks. Sometimes systems have very slow leaks or the leaks reseal after time. It is better practice to charge it, look for obvious leaks and then see how it does than it is to spend hours looking for a leak that may not be found. It costs you more money and the tech more time. Hopefully, you used a reputable company to charge this system.
Posted on Feb 07, 2010
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
Auxilliary heat just started blowing cold air
SOund like you heating element has a open limit or the sequencer is bad. Another thing that it may be is the element wire has broken. Either way it sounds like you need a technician to come out and repair.
Jan 27, 2009 | Honeywell TH4210D1005 Heater
3 amp fuse blows after three hours on Goodman 4 ton 16 seer pump
I would suspect you have a problem in the defrost circuit of your heat pump. there are a couple of things you can try. first just run the system on emergency heat and see what happens. you could have a defrost board that is shorting when it kicks into defrost. it sends a signal back to the furnace so it will come on during defrost. if you do not blow a fuse as long as you are running in emergency heat, i would suspect the defrost control board. also you could have a dead short in the wire that runs from the "w" terminal on furnace control board, out to the heat pump. keep in mind that any of the wires could be the cause and i am just tying to give you the most common things. your furnace will still run if you unhook all the low voltage wiring out at the heat pump. if you do this and stop blowing fuses. you know it is something on that wiring. goodl luck.
Jan 26, 2009 | Haier Energy Star ESA3183 Air Conditioner
No heat new thermostat
you have a short in the wireing.disconnect at air handler and hook-up short t-stat wire to t-stat,ifok chk wire to condenser
Jan 10, 2009 | Heating & Cooling
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Heat Pump Stops Working only in the Early Morning
When the unit does what you say does the fan motor outside stop also , if it does that means it is in defrost mode and should kick back over to normal after the system heats up the coil enough
Nov 24, 2008 | Weather King 12AJA4801AH Air Conditioner
Heat Pump/Furnace Trip Circuit Breaker
My system will run for a short period and then suddenly trips the circuit breaker in the main panel for the heat pump.
I have a Goodman - 3 ton system about 8 - 9 yrs old. I'm being told that I need to replace the heat pump/air conditioner compressor?
What do you think?
Oct 22, 2008 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
108 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
