Question about Kenmore Elite 45986 Front Load Washer
Broked Spider on a Kenmore Elite H3 washer.
Can the spider be purchased without buying the whole basket? I ca not seem to find the spider and shaft by themselves.
  • muinmdw Feb 07, 2010
    is it can or can't. If the Shaft is part of the basket how can I buy that seperately
  • 572 Answers
U can buy them seperatly. the shaft is part of the basket
Posted on Feb 07, 2010
W10269756 spider
Nope. They just want you to buy a new washer apparently. Like you would spend $600 on a friggen basket. Good lord.
Feb 02, 2014 | Washing Machines
Bad bearings or the inner tub mount called a spider. Buy a new washer. sorry :(
Nov 15, 2013 | Kenmore Elite 45986 Front Load Washer
Lg wd 10264
follow this steps and fix it. God bless you
  • The basket spider provides support and stabilization for the washing machine's basket. It is located at the back of the basket and has three arms, which are attached to the basket by three bolts. Although the machine's basket is made of stainless steel, the spider is not. It is composed of an inexpensive, white, aluminum metal, also known as "pot metal," which is subject to corrosion. Eventually, the aluminum or pot metal deteriorates to the point where the spider breaks during a wash cycle - accompanied by very loud noises. According to one repairman, the sound mimics that of a car collision. The amount of corrosion behind the basket can be enough to fill a pint container.
Life Expectancy
  • The spider basket in a front-load washing machine does not have a long life expectancy. According to the appliance repair website Suds and Service, pot metal basket spiders in small front loaders, those with a capacity of 16 lbs. to 17 lbs., have a life span of only five to six years. These short-lived basket spiders are found on several washing machine brands, including Kenmore, Frigidaire, Electrolux and White-Westinghouse, as well as Gibson, Tappan, Wascomat and some GE washers.
  • Sponsored Links
Replacement
  • Replacing a front-loading washing machine's broken basket spider is expensive. Although the spider is removable from the basket, washing machine manufacturers do not sell the spider as a standalone part, so you must purchase an entire basket. At the time of publication, the price of a basket and spider ranges from $259 to $470 depending on the manufacturer. When combined with labor costs, replacing the basket and spider can cost more than $600.
Read more: http://www.ehow.com/info_12176732_causes-basket-spider-break-frontload-washer.html#ixzz2aSx3lP95
Jul 29, 2013 | Washing Machines
HOW TO REPLACE SPIDER ARMS ON KENMORE 970-C42062-00
if the spider gear is gone and it's very loud in the spin cycle buy a new washer,you have to take the whole washer apart,and then take separate the tub,with all the time and money it would be better to replace the washer,if you look inside at the back of the tub,you'll see like a peace sign,that's where the spider gear is.
Mar 31, 2013 | Kenmore Washing Machines
The drum on my kenmore elite 45862 frontloader seems to have seperated from the outside ring. can it be fixed or do i need a new washer
the spider trunnion has broken apart that connects the inner basket to the rear shaft where power connects from the drive motor to turn the drum,most brands you must replace the inner basket and spider trunnion as a unit, as they are not sold separately it will cost you about $350.00 plus oversize shipping
Oct 27, 2012 | Washing Machines
My duet makes a loud (out of balance sound) when spinning @ high speeds. (it's not out of balance tho) the outer plastic drum seems to have a groove worn into it
The problem is the dreaded broken spinner support or what is called the spider assembly. It is the three-arm assembly that holds the basket to the shaft. Unlike the basket which is stainless, the spider is made of aluminum that corrodes with time and usually breaks during the 6th or 7th year of the machine.
The bad news is, the spinner support cannot be purchased separately. It comes as a complete assembly with the basket which is covered by at least a 10-year warranty. The most frustrating fact is that the spinner support is not covered by the same warranty even though they come as an assembly which costs at least $500, a non-economical repair to invest.
Here are some videos of owners of Sears Kenmore Front Load Washers who had an issue with the spinner support. Most Sears Kenmore Front Load Washers are manufactured by Whirlpool like the ones in the videos.
Aug 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a kenmore elite washer mod. 970-c40062-00 ser. xc11700832. the washer leaks, and is very noisy. It is 10 years old
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 Front Loader Washing Machine tumbler
The metal basket (inner basket) has a broken spider (these are the support brackets that hold the basket to the bearing shaft). The inner basket will need to be replaced and the front and rear shell of the drum may also need to be replaced depending if any other damage has been done. It's a big job, about 2 hours for a good tech.
Feb 19, 2009 | Kenmore Elite 45986 Front Load Washer
Knocking noise
Your problem may not be a broken spider assembly. My Kenmore Elite (model # 110-42822-203) had a kocking problem as well. After taking the back off, I discovered that the nut holding the pulley to the drum shaft (on the outside of the outer basket) was slightly loose. I simply re-tightened this an the knock went away. The pulley was shifting on the shaft ever so slightly, leading to the knock. Cost of fix: $0. :-).
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Off balance, loose drum?
If your machine produces a lot of banging noises when in a permanent press final spin you may be experiencing a broken spider. It is a part which is not made from stainless steel metal, but attached to a stainless still drum (tub spin). So, when it is soaked in water all the time during a normal operation of a washer it creates a galvanic element between a stainless still drum and itself. This results in severe corrosion of the "spider" and then leads to it's breakage. To check if you have a broken "spider" open the door of the washer and try to kick your internal drum back and forward while rotating it slowly.If you will hear clicking noises (metal to metal) in some position of the drum it means that your spider is broken. The replacement of this spider will require complete disassemble of the drum. Most likely you will end up replacing this whole part
Drum assembly, spin basket Part # 131618500Another way is get just a spider part, it's doable, but may be tricky.
Cheers!
Oct 29, 2008 | Kenmore 44042 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
418 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
