Question about Dell Inspiron 1526 Notebook
Notebook does not boot up at once when turned on. Dell logo does not appear but the power button is lighted. However if you turn it on and let it stand 5 minutes and then turn it off and then turn on again, the laptop turns on immediately and works perfectly. The problem comes back only if you turn off the laptop for a long time because when you just turned it off and then turn it on right away, it turns back on smoothly. It is like you need to warm up the laptop first for 5 minutes before it will start to work smoothly. What do you think is wrong?
Hi vsalacup, I have exactly the same problem. How did you solve yours? I have turned hibernation off and deleted all hiberfiles and tried many other things - the problem still persists...
Posted on Jun 08, 2010
  • Dell Master
  • 12,061 Answers
Hmmm sounds like an hibernation problem try removing all but the last hibernation point, better still. remove them all. Defrag the drive also.
Posted on Feb 07, 2010
Dont startup
1 Turn on the computer.
2 As the computer starts, press <F8> on the keyboard until the Advanced Boot Options menu appears on the screen.
new_note.jpg Note: You must press <F8> before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Dec 14, 2013 | Dell Inspiron 1501 Notebook
Dell Inspiron 1440 notebook cannot start.
I have seen these symptoms before when the hard disk drive has failed. It will hand on the POST screen (The part with the DELL logo) for slightly longer than usual due to fault with the drive, after that it will attempt to boot and error from the hard disk so quickly you see nothing but the laptop appear to cut out. Although the hard disk is the most likely thing to be at fault these issues could potentially be caused by any one of the parts within you laptop being broken.
If you are fairly tech savvy try downloading this utility "Seatools" http://www.seagate.com/support/downloads/seatools/ burn it to a bootable CD. Put the bootable CD in you DELL laptop and boot off it, by pressing F12 and selecting to boot from CD/DVD drive. Then run a "Long test" once this test is complete the software will advise you whether the hard disk is faulty or not.
If you are not confident in trying this I would recommend taking the laptop to be diagnosed by your local computer repair business.
Jan 07, 2013 | Dell Inspiron 1440 Notebook
Dell Precision M90 no boot and device status light next to power light is green
Here are Few steps which can use to trouble shoot your laptop no display problem.
1. Connect a VGA
cable for external monitor and check if you can see any display on External Monitor.
2.Take out your RAM and Clean it with Pencil Eraser and Put it back. If Possible try with different RAM,
3. Remove your Hard Drive and Try switching on Laptop without the Hard Drive.
4. Make sure that you are using proper Adapter with proper Voltage.
Aug 10, 2012 | Dell Precision M90 Notebook
My dell won't boot up. All that comes up is a blank screen. Any suggestions?
Remove any CD/DVD disk from the CD/DVD drive.
If pressing the ON/OFF button causes any lamps to light, then the external AC adapter probably is OK.
If pressing the ON/OFF button causes a message like "press <DEL> (or <F10>) to enter setup mode", then press that named key.
Once inside BIOS SETUP, check that the disk-drive has been "detected". If not, then the disk-drive could have "died".
If all else fails, take the computer to a qualified technicican.
Aug 18, 2010 | Dell Inspiron 1100 Notebook
POWERS UP BUT THEN FREEZES AFTER ABOUT 4 MINUTES
Need to test and isolate where it exactly freezes? After dell logo, after windows logo or while inside windows? Now, if it only freezes inside windows try to turn off your windows updates and antivirus first and check if still freezes, if yes then try booting in safe mode, reboot system then keep tapping on f8 once dell logo appears. Check if laptop keeps freezing in safe mode. Please let me know.
Oct 01, 2009 | Dell LATITUDE C600 PIII 750MHZ 128MB 15GB...
My dell (monitor) it turns on few secons but the image goes off,
First you'll have to power off the system.
Please power on the system and as soon as you see the Dell logo please tap the F2 button 3 - 4 times.
The computer will go to the system setup. Check if the screen goes blank here.
If the screen stays on then try this.
1. Please power off the system.
2. Please power on the system and as soon as you see the Dell logo please tap the F8 button 3 - 4 times. You'll reach the Windows Advanced Boot Options Menu on the screen.
3.Select Safe mode with Networking.
4. Select Administrator at the log in screen.
5. Warning dialog box with the message Windows is running in safe mode. appears. Click the Yes button.
6. The desktop appears with the words Safe Mode appearing in all four corners.
7. Uninstall the video drivers and restart the computer.
8. Resintall the video drivers.
Rate if useful.
Aug 19, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Hang at startup (BIOS)
Yes laptops can work without battery.
If the laptop is hanging on Dell logo and entering into BIOS then normally it is HDD issue but you have already checked without HDD so might be it is RAM or Board issue.
You can check with PC 133.
Please check your Laptop with minimal boot once (by removing all external hardwares like modem,tv tuner or graphics if any) and if you are geting the display one of the devices is causing the issue whch could be diagnosed by connecting one by one.
Feb 09, 2009 | Dell Inspiron 2500 Notebook
Dell D600 Wont turn on sometimes.
Reseat the harddrive (take out the screw and slide it in and out)
You can run diagnostics, during startup (just after Dell logo) press F12,then select Boot to Utility partition, or Diagnostic partition.
It may reveal you issue
Hope this helps
Feb 04, 2009 | Dell Latitude D600 Notebook
Dell Inspirion 1000 power short circuit
Good Evening:
Hope that you are wellJ
  • There appears to be a shortage in one of your lines to you computer. But, before you replace anything, try these methods.
  • Shut down the computer.
  • Remove any CDs, DVDs or external storage devices (like USB keys or external hard drives) from the computer, if any are present, then press the power button to turn the computer on.
  • Press and hold the <F8> key as your computer starts. You need to press <F8> before the Windows logo appears.
  • If the Windows logo appears, and the system still fails to boot to Windows, shut down the computer and try again.
  • From the Advanced Boot Options menu, use the arrow keys to highlight Repair Your Computer, then press <ENTER>.
  • Click to select your language, and then click NEXT.
  • Log in as a user with administrative rights, and click OK.
  • From the Choose a recovery tool menu, click Startup Repair .
  • Once completed, click FINISH.
  • Click RESTART.
If I can be of further assistance, please let me know
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful weekend.
Oct 03, 2008 | Dell Inspiron 1000 Notebook
Booting problem
Try putting the computer into safe mode by holding down on the F8 button and selecting safe mode during the boot process. Once you get to the safe mode screen and windows appears, restart the computer.
If that doesn't fix the problem you will have to restore Windows.
Jun 12, 2008 | Dell Latitude C640 Notebook
Dell Inspiron 1526 Notebook Logo
504 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
