Question about Behringer Pmp3000 16 Channel Audio Mixer
I have a beringer 5000 mixer and can not get no sound from it. it's like the speakers are not getting power
  • Behringer Master
  • 5,603 Answers
Oh, oh... got one on the bench now... There is a design defect that causes a short and destruction in the power amp portion.
Do a test: Plug headphones into the main 1/4 inch jacks. The sound won;t be very loud since these are line outputs, not for headphones.
IF you get sound out those, then one or both power amps are dead.
Worst case: if one amp is dead, several parts including three power MOSFET transistors are fried for any of the dead channels.
The failure of the amp can wipe out the main power supply. If you effect windows light up, then the small power supply is operating.
If the big supply is fried, there are two large MOSFET switching transistors that are gone. Often several smaller transistors and dides and resistors and one switching IC goes. MOST of these are surface mounted parts and would be beyond the scope of what you can repair.
I am trying to contact Behringer about the flaw but haven't heard back yet.
The nature of the flaw is this: The is insufficient clearance on an internal circuit layer from the edge that fits into a slot in the power amp heatsink. Any humidity that enters can cause the insulation to breakdown and arc to the heatsink causing a chain reaction.
I repaired one of these already before finding the cause, but this one had a smoking gun! I just yesterday milled out the slot deeper and wider and will put insulating tape to prevent further arcing. The arcing that had occured burned away the internal layer and the connections. I will replace thoose with hardwire.
Repair of this problem is time consuming to weed out all the blown parts and to safely bring the unit back to life.
The current unit I am working on took out ONLY the power amp. A 30 milliohm resistor went up in smoke making a real mess. All three power MOSFETS are gonzo and a zener as well... don't know what else I will find. The previous unit was worse as the power supply was wiped as well.
Posted on Feb 07, 2010
Shud i get an external equaliser? i'm using MG166CX 16-Channel Mixer as the main mixer.
An external equalizer will not help this at all. The problem is likely within the amp (feeding the main speakers), the connections from the board to the amp, or the speakers themselves. In other words, the answer would be "NO." Best of luck!
Jan 14, 2013 | Music
I dont know how to connect my gem sound trf152 speakers
Looks like it takes regular home theatre speaker wire. If this is a powered speaker (like a JBL eon g2), then all you need is a passive mixer, and connect the speakers to the mixer. If this is not a powered (amplified) speaker, then you will need an amplifier to boost the sound source and drive the speakers, so you would connect the mixer to the amplifier, then the amp outs to the speakers.
Apr 14, 2012 | Gem Sound TRF152 15 Pro DJ PA Speaker
Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Feb 16, 2012 | Behringer Music
I have a beringer sx3242fx, i need to know the best compatible amplifier to use my samson speaker that pushes up to 500 w
Almost any amplifier will work so there is no "best"... Just make sure the amp RMS rating is a bit below the RMS rating of the speaker for safety of the speaker. A QSC GX5 would be a candidate. You would use one side of it for each speaker if you have two, or use only one side for a single speaker. A lot of pro's seem to use these amps. USE BALANCED interconnections either XLR or TRS cables AND for sure power the amp and the mixer from the same receptacle... it often means running an extension cord like the pro's do to avoid ground bounce noise AND damage to the equipment.
Sep 02, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
Pls, i will like to know how i can get a pro sound with my beringer b2pro mic with my xenyx 1204usb mixer. i mean mic settings
The mic will give very good sound assuming you put it in a studio environment and have no speakers being driven by it that the mic can "hear" or it will feedback instantly.
Your studio should have proper sound deadening on the walls ceiling and floor. There is a lot of information on the web about setting up a studio. Search for it with google. The more studio-like the environment, the more like pro sound you will get. You will NOT get pro-sound in a bare garage or a room in a house without handling the sound reflections in the room. These mics hear EVERYTHING... they are a high quality mic.
Feb 25, 2011 | Behringer B2PRO Gold-Sputtered Large...
None of the channels work. Most of the LED lights work. Im going thru the beringer mixer for power but using another mixer.
If you plug into the PA input or inserts of this unit, that DISCONNECTS all the mixing channels within this unit and none in this unit will work. That is how it is supposed to work.
If you wish to use another mixer as well as the channels in this, I suggest you run the other mixer into one of the stereo channel inputs OR the CD inputs, although the CD are NOT balanced inouts and subject to higher noise level.
Feb 01, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Can't get any gain without feedback when using my new shure sm81 mic and the xenyx x1240usb fx mixer. keep the speaker way out in front of me. no montiors. using just a hair of reverb and compression. have...
This is a STUDIO mic and CANNOT be used in the presence of speakers that are driven from its output.
There is special hardware processors to cancel feedback but you do NOT want to go there !!!
This condenser mic is to be used in a studio where performers wear earphones and NO monitors are present.
You should use a Shure SM58 or other CLOSE talking cardoids if you have speakers in the area.
Jun 09, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have a beringer pmp 5000. Out of the box, I
Yes, the fan is temperature controlled. You have to drive it a bit before it runs, and then it is kind of throttled versus temperature.
Sep 20, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
I have a beringer eoropower pmp 5000. i run my mains and monitors in mono how do i turn the volume up for my monitors
With the AB switch at the center position Mon1/Main you control the volumes INDIVIDUALLY with the MON pot for each input that is a couple positions above each of the input sliders.
Aug 26, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Behringer Pmp3000 16 Channel Audio Mixer Logo
300 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
