Question about Fujitsu ScanSnap Manager
The feeder on my ScanSnap S510 doesn't work. I press the green button and nothing happens and then the computer screen says there is no image. So the scanner seems to communicate with the screen but doesn't scan the paper.
SOURCE: driver scansnap
What needs to be deleted in the registry?
Posted on Sep 12, 2008
SOURCE: error while attempting to install ScanSnap Manager on Win XP Pro
Bypass installation wizard and just run the setup.exe file for ScanSnap Manager. Installation wizard is bugged.
Posted on Jan 12, 2009
SOURCE: noise when scanning document
Visually check the clutch spring (located on the left side of the pickup roller shaft, just before the gear). If the spring is deformed or broken, replace the entire pickup roller shaft. The part you need to order are shown below. You will also need a small 'C' clip. I do not know if the clip comes ith the shaft or the gear...
PA03360-Y110
Pick shaft
PA03360-Y112
Pick Bearing ‘M’
PA03360-Y107
Clutch
PA03360-Y106
Clutch Spring
PA03360-Y105
Pick Gear
Regards,
Eric F.
Posted on Feb 06, 2009
JulesPCaut
  • 702 Answers
SOURCE: problem installing Scansnap S510
This is probably due to the program using the same folder for the new version of the program. Best solution would be to uninstall the new version, uninstall the old version and then reinstall the newset version only.
Running a registry cleaner in between does not harm.
One other thing to try is an uninstall program, but I am not sure that will help.
Posted on Apr 23, 2009
  • 6 Answers
SOURCE: My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
Posted on Jul 13, 2009
How to load scansnap s510 on new computer with windows 7?
Hi irene
scansnap s510 drivers (win 7/8) can be found at
driverupdate us . (32/64 bit)
It will take 2 mins from you to install... after updating, go to word and try to print something
I hope I have helped you...
enjoy
Mar 19, 2012 | Fujitsu ScanSnap S510
Everytime i try to scan any document using my Fujitsu ScanSnap S510, the blue light on the front-right side of the device blinks 3 or 4 times and nothing else happens (the document, therefore, is NOT...
I had a similar problem. All I did was unplug the USB cable from the scanner and reattach it. Sometimes I would have to close scansnap (blue "S" icon in the sys tray at the bottom right), and then power on the scanner.
Nov 28, 2011 | Fujitsu ScanSnap S510
My ScanSnap has worked flawlessly for years. I just tried to scan and got the following message: undefined error occurred.(0xffffdcf7) Won't scan. Tried to reboot - no luck. Let me know...
The same thing happened to me. In a nutshell, you have to install new drivers. Have you recently upgraded your system to SnowLeopard or Lion? I did, and that's what went wrong.
To do:
1. Make sure you have the latest ScanSnap manager: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac.html
Install that.
2. Get the Lion update: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac-mg22.html
Install that.
3. Open the new ScanSnap Manager (v 2.2). Delete the old one from your dock, so you don't get confused.
4. Scan away.
Aug 06, 2011 | Fujitsu ScanSnap S510
Computer says scanner is ready to go, lights are blinking, but scanner will not scan paper through.
Go under the advanced settings for the scanner and select ADF (Auto-document Feeder)
Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I can give you more information on the specific method for setting this up if you need it, but would need model and make of the scanner.
Apr 13, 2010 | Fujitsu ScanSnap S510
Scansnap s510 is being used by another program
As per your instructions i have Uninstall every driver/software that is associated with the printer after computer has been restarted, install the printer driver afresh and connect the printer to the compute it works but after sometime it shown again same error
Feb 19, 2010 | Fujitsu ScanSnap S510
Sending E-Mail Failed (0x80004005) - Fujitsu ScanSnap S510
You need to open Internet Explorer and add Thunderbird as your email program. Click Tools > Internet Options > Programs tab > E-mail: Select Mozilla Thunderbird from the drop down.
Jul 19, 2009 | Fujitsu ScanSnap Manager
When scanning mulitiple pages, it takes more than one page into the feeder
it harpen because the papers are stuck together, please always seperate the papers before loading into feeder.
Jul 16, 2009 | Fujitsu ScanSnap S510
Bought my ScanSnap S510 just about 3 months ago. I am going back to Mac for my operating system. Is there a way to run the S510 on my Mac. I love the scanner but don't want to spend another $500 for...
Check out:
http://forums.macosxhints.com/showthread.php?p=527817#post527817
The Fujitsu ScanSnap V2.2 L11 drivers have been patched by me to work with S300, S500, S510 and fi-5110EOX/2/3 PC-based scanners for the MAC. No need to buy a new scanner. Just apply the patch and then send me a Christmas card! ;)
Hope this helps!
Mar 28, 2009 | Fujitsu ScanSnap Manager
Computers & Internet Logo
325 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
