Question about Electrolux Washing Machines
Ewf1073 cannot run. A padlock sign is appeared in the screen. What to do? Thx
  • 572 Answers
U have to unlock the pad. child lock feature
Posted on Feb 07, 2010
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
May 07, 2014 | Zanussi ZWF1640 Front Load Washer
Locked out of thermostate
From the manual:
PROGRAMMABLE KEYPAD LOCK
To prevent tampering with any of your settings or
temperatures, the front panel buttons and the rotary dial can
be locked out, requiring a four digit code to unlock them.
You may use either the default lock code of "0000", or your
own personal number combination (see "Changing The Lock
Code")
LOCKING THE THERMOSTAT: Ensure the rotary dial is in the
RUN position. Press the NEXT button for at least 2 seconds.
The words "ENTER CODE" will appear on the screen, along
with "0000". Press the NEXT button again for at least 2
seconds. A padlock should appear on the screen to confirm
that the thermostat is now locked.
UNLOCKING THE THERMOSTAT: Ensure the rotary dial is in
the RUN position. A single press of any button should cause
the words "ENTER CODE" to appear on the screen, along
with "0000". If the default code was used to lock the
thermostat, press the NEXT button for at least 2 seconds.
The padlock should disappear from the screen, and the
thermostat should now be unlocked.
If you try to unlock the thermostat by entering a code that is
not correct, a padlock and the digits "88:88" will flash on the
screen and you will have to try again. If a lock code
different from the default was used, this will need to be
entered by using the UP/DOWN buttons, and the NEXT
button to advance to the next digit. Once the correct code is
entered, press the NEXT button for at least 2 seconds and
the thermostat should now be unlocked.
CHANGING THE LOCK CODE: To create your own specific
lock code, first ensure that the rotary dial is in the RUN
position. Press the NEXT button for at least 2 seconds. The
words "ENTER CODE" will appear on the screen, along with
"0000". Now press the HOLD button again for at least 2
seconds. The words "SET CODE" will appear on the screen,
along with "0000".
IF YOU FORGOT YOUR LOCK CODE: You can still unlock the
thermostat by performing the following steps: On the back
of thermostat locate JP1, which is a row of 3 metal pins at
the right edge of the circuit board above the battery tray.
There should be a plastic jumper cap on 2 of the 3 pins
(right or left).
Move the jumper cap so that it is on the opposite 2 pins.
For this change to be recognized, move the Temperature
Mode switch to any other position than its current one.
These steps listed should have changed the lock code back
to the default of "0000". Follow the instructions already
listed in "UNLOCKING THE THERMOSTAT".
Sep 02, 2012 | Lux Tx9100e 7 Day Universal Programmable...
I accidently sat on remote for centrex t.v now all i have is a blue screen and a red padlock sign, how do i unlock
pls check hideen key on remot cantrol
try digit key [- - -] preesing 3 to 5 sec. and see key lock is off than re set preesing 3 to 5 sec and see on the screen tuning lock is off
or
lock key on remot cantrol pls. press 5 to 10 sec.and see the screen red padlock is opan or green then try remot cantroll any function use normaly
Oct 26, 2009 | Televison & Video
Padlock appears on screen
The padlock is an indication that the On Screen Display is locked. You can also lock or unlock the OSD by pushing the Menu button for over 15 seconds.
http://support.dell.com/support/edocs/monitors/e171fp/en/controls.htm
Sep 30, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Centrex television
I found the solution online - you have to press the rectangle button for at least 4 to 5 seconds that is at the bottom right of the remote that has a + sign on it, like magic the padlock disappeared and I had a picture again.
Jul 20, 2008 | Televison & Video
Hold the menu button until the padlock unlocks, it takes anywhere from 30 seconds or even a minute or so
Mar 12, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Washing Machines Logo
290 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
