Question about Comfort Zone CZ-441 Ceramic Heater
Will not come on
Heater was working fine, and then I turned it off. When I turned it back on, it will not do anything.
    Genius:
  • 1,199 Answers
L;ook for fuse!
Posted on Dec 09, 2008
2005 chevy impala passenger side blows heat out continuously, driver's side works fine with heater & AC
You may find a reset will solve this annoying problem. The problem you have is the GM heater control unit has lost it's calibration, which can happen from time to time. The way to reset it is, start your car and turn your heater off, and shut off the car, pull out the keys. Then with vehicle off, disconnect the battery, (or batteries if it has two). Let sit for 10 minutes, then re-connect battery. Get in and start the engine, DON'T touch anything, let the heater control unit re-calibrate for at least 40 seconds, (by the clock), then try turning on the heater.
Jul 18, 2013 | Cars & Trucks
3500 propane forced air reddy heater not putting out much heat since I changed bottles
tank is being turned on to fast and the safety valve will close and not let the full pressure go to the burner same with any new tank that has the columbine valve in it pressure sensitive
Mar 25, 2013 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heater
Possibly a bad heater blend door actuator. You get to it by removing the radio. Part is about $35 from auto parts store. Another issue due to plastic gears....... Warning -- don't drop anything back there -- use a cheap flashlight - you may never see it again.
Nov 19, 2011 | 2000 Ford Windstar
Hello i havent Used my ready heater 60000 btu since last winter. It was working fine when i unpluged and emptied it...now when i plug it up i hear a hum and nothing else no blower or anything....could ude...
The fan motor is setup...
Tear it part and get some WD-40 worked into the motor at the shaft end... then when you get it spinning freely... get some light motor oil worked into the bearing...
Works best if you can tip the heater back so the WD-40 and oil naturally run back into the motor...
heatman101
Dec 13, 2010 | Reddy Heater-30-55,000 BTU Variable
Wall heater new 07, worked great all last season, turned on this
there could be something stuck in the pilot assembly since you added a new tank to system. Check to make sure flame is hitting thermalcouple. Can you wait for a repair man to come and take pilot assembly out and clean. He will also replace thermalcouple. If you can't wait and you feel comfortable with taking pilot assembly out. Turn gas and electric off to unit then pull cover panel off. Pilot assembly is held in with two screws. Take tube off of gas valve and take off thermalcouple line off gas valve too. take out pilot assebly. Once you have it out take gas line off bottom of pilot assembly. There is a orfice in side make sure you can see through the orfice. You can also clean thermalcouple with a wire brush or sand papper. Reinstall pilot assembly make sure all fittings are tight. turn gas back on and light pilot. If everything looks good turn power on. Turn heat up run heater for a few minutes then turn heater down and let sit to see if it will stay on.
Nov 27, 2008 | Empire GWT-25 Wall Mounted Panel Heater
Climate control
it is your blend door actuator behind the dash - hard to do but possible, my opinion would be to take it to the shop
Oct 17, 2008 | 1994 Ford Thunderbird
Bionaire BH3950 Does not heat
I'm not an expert, but I have two of these units that are working fine.
The on/off switch (the top switch) has a light in it that illuminates when the heater is on and heating. If this light comes on and there is no heat, then the element is probably burned out.
The heater has a safety switch that prevents the unit from working if it is not upright. If the heater was stored for any length of time on its side, the safety switch might have stuck in the off position. Unplug the heater and with the heater upright, try shaking it or slapping it firmly with your hand to se if this fixes the problem.
If none of this works, then as sunmasc says, the thermostat is bad.
Jan 12, 2008 | Bionaire BH3900-U Oil Filled Radiator...
Oil filled Heater will not turn on and heat.
First thing make sure: · Ensure that your circuit breaker or fuse is working properly. · Be sure the heater is plugged in and that the electrical outlet is working properly. · Check for any obstruction. If you find any obstruction, turn the heater ?OFF?. Unplug the heater and wait a few minutes for it to cool down. Carefully remove the obstruction. Plug the heater in and turn it on again by referring to the OPERATING INSTRUCTIONS. Second, If you're NOT still under warranty you should at least open the heater and look for anything strange like a blown fuse. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace.
Dec 03, 2005 | WeatherWorks CH3001 Oil Filled Radiator...
Comfort Zone CZ-441 Ceramic Heater Logo
220 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
