Question about Dynex Wireless-G Broadband Router
Have a Dynex Wireless G Router I've used for some time now and suddenly can't get wireless connection. When working with it, I now cannot get a power light. When I unplug and plug back in to the power outlet the power light comes on, it goes through it's cycle and eventually all the right lights come on, but suddenly they all go dark. It's like the router suddenly looses all power. I've check the wall outlet and it's good. Any suggestions, or is this router just fried?
    President:
  • 949 Answers
Did you try and wiggle the plug, at the unit, if the lights flash its a bad connection.
Check the power supply, as it first turns on, then check it after it powers down, if you have the same dc v then the power pack is bad.
But it sounds like the router is going bad, so the only thing you rally can do, depending on where you bought it and how old it is.
Say its only a few months old, and you got it from walmart, try and return it.
Contact the MFG through there website and find out if they will take
care of the problem, if any charges need to be paid, and the cost of shipping, put this all together and see if its just better to go buy a 50.00
new one.
I hope you get this resolved, and if any other questions just ask.
Posted on Feb 07, 2010
    Scholar:
  • 137 Answers
I would just say it's toast.
Me personally I would go buy a new one and get it over with.
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
Router working as Access Point, unable to access via we browser
Please try first plug out the router and plug in again then press & hold the reset button till the power led become red and release. If that doesn't work, plug out the router, pressing and holding the reset button plug in the router.
Let me know the result please.
Thanks for joining Fixya.
Have a good day.
Feb 22, 2010 | Dynex Wireless-G Broadband Router
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
I have had a wireless dynex router for awhile and it has been working fine using wireless then when i plugged in my computer and xbox 360 to the router it has made the computers using the wireless internet...
it is getting limited or no connectivity because it is actually not connected even though it shows.the best resolution is that change your entire wireless settings and then connect all wireless devices like computer and xbox 360 again it will connect.I use to do the same when i use to work for netgear.
that will fix..
Jan 04, 2009 | Dynex DX-E401 Router
No Connecton with wireless computer
it just means tat the connection is secure
wat you could try would be
1) take out power for modem then dynex router
2) power the modem n then router
3) if this doesnt work you would have to redo the wireless setting on the computer
Dec 23, 2008 | Linksys Wireless-G WRT54GS Router...
Wireless signal keeps dropping/dissapearing
Check my tip
Using Router and Wlan adapter from different brand (Dynex + Belkin) is sometime calling for trouble: you must configure both to be sure to be on same standard (or change Both).
I'm using Netgear + Belkin and tune is not easy
On router config check radio power, reduce the used standard (B/G A/N) to the only one used by Belkin adapter (N).
Be sure you removed Windows zero wireless configuration (= use windows to manage my connection= OFF)
edit your belking wireless networking utility to automatic reconnect:
try downgrading to G standard from router side
Check your network connection plugging your laptop to router via lan cable.and check network params (DHCP DNS etc.).
Then check wlan connection near router, if you experience wlan drops only when far from router, find any possible interferences source (Microwave, cordless, remote) remove it or be ware you cannot have wlan when your wave is working.
Dec 13, 2008 | Dynex Enhanced-G Wireless Broadband Router
Can  Dynex 4 Port Router DX-E402 be used to connect internet on a notebook without using cable to notebook?? i.e. Can it be used like a wireless g router??
Unfortunately, the DX-E402 is not a wireless router, so it can not transmit its signal without a physical cable connecting the router to your computer. If you want a wireless router that can also connect to your ISP, check out the Dynex Enhanced Wireless G Router:
http://www.dynexsupport.com/product/?pid=DX-WEGRTR
Nov 28, 2008 | Dynex 4-Port Ethernet Broadband Router...
Siemens router & Dynex adapter
Double check if there is any wireless security enabled in your router. Verify if the type of security enabled in your router is already supported by your wireless adapter. If the wireless security enabled in your router is not supported by your adapter, change the security to something that will work with your adapter.
Try connecting your computer with dynex Wireless G USB to different wireless network for further isolation.
Oct 02, 2008 | Dynex Computers & Internet
Need help with best connection type for college student in dorm
The enhaced version just give more range of signal over the normal dynex, regarding the internet provider it depends because sometimes you'll need a password and user to connect to the wireless signal. The dynex is used to connect from a cable signal (RJ-45)internet and then it will transfer the connection to wireless so it can be use from any laptop with wireless connection. So for example you DSL internet connection is a cable (RJ-45) then you connect that cable to the dynex router, then the router will automatically transmit the signal to wireless so any nearby pc can connect to it. If the laptop doesn't have wireless, then you'll have to buy a card to be able to connect to wireless signal or you could by also a (RJ-45 straight-through cable Cat 5e) to connect from one of the ports from the DYNEX to the laptop. Hope it helps.
Aug 19, 2008 | Microsoft Xbox 360 Console
Establishing a Network Connection
First whether the connection is pinging or not if pinging means its working may be the ip address problem
Feb 14, 2008 | Computers & Internet
Dynex Wireless-G Broadband Router Logo
463 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
