Question about Dayton 1VNX2 Oil Filled Electric Radiator Heater
The thermal fuse has blown, does that mean that the thermostat no longer works or should it be safe to use on a low setting?
  • John Hart
    John Hart Apr 11, 2013
    Thank you Kim. The fuse is flat and screwed to the element housing. I can only find round fuses that appear to be separate - not fastened down. Will this work safely?
  • 1,476 Answers
The thermal fuse protects you and your unit from overheating. You would need to replace the fuse to have it work. Let me know if you need more help.
hardrocko
Posted on Feb 07, 2010
Dryer does not heat up
Hi.
Start checking if the ignitor is working and if flame is coming on. If igniter is not working, replace the igniter. If there is no flame test the coils contacts using a multimeter set on Ohms. The coils must return continuity between two of their contacts or they are defective and the valve will not be open. Replace defective coils if needed.
Test and replace the thermal fuse.
The part is tested touching the fuse contacts with the probes of a multimeter set on Ohms. If the fuse is good it will read zero. A bad fuse shows Ohms infinity (open).
If fuse is not the culprit, then you will need to reach the thermostats, testing them with the multimeter. apart the thermal fuse there is one thermistor and one thermal cutoff.
When you access the thermostats clean the lint from air ducts. If fuse or thermostat has blown it means that lint or poor ventilation has caused overheating.
Check fuse if problem is not fixed test the thermostats.
Regards.
Ginko
Jun 14, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag Performa dryer is not heating at all .What should i do? Everything else works it just doesnt heat.
Hi
Replace the thermal fuse, and if possible test the heating group (thermostats and element or gas heater). You can replace the fuse straight away, or you can first test it using a multimeter set on OHMS. If the multimeter reads Ohms infinity when you touch the fuse contacts with its probes, then the fuse is gone.
If the fuse is OK, then you can have a defective thermostat or heating element (electric models), with gas models you test coils, thermostats and ignitor (flame sensor rarely fails).
After fixing the problem clean lint from air ducts, if the thermal fuse or thermostat has blown it means that there had been overheating.
May 09, 2011 | Maytag Dryers
Dryer will not get hot
Hi
May 08, 2011 | Dryers
It appears as if the heating element is no longer working. I can hear the relay clicking on once I press the brew button but the plate doesn't get hot and no steamed water vapor enters the brewing basket....
Your problem is probably in the heating unit or boiler at the bottom of the unit there is a thermostatic switch attached with a spring clip and another device called a thermal fuse attached also with a spring clip. if the thermostatic switch welds closed due to repeated on and off action the heater or boiler will get dangerously hot enough to cause the thermal fuse to blow saving a call to the fire department. If the fuse is blown it probably means your thermostatic switch is stuck in the closed position and needs to be replaced. I have designed a modification to remove the heavy 10 amp load in the thermostatic switch and redirect the heavy current to an external relay and I am now using that to see if the unit will continue to work.longer than the original design. The circuit is pictured on another post on"fixYA"
Nov 27, 2010 | Mr. Coffee FTX20 / FTX23 Coffee Maker
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
The dryer is not drying. The drying temperature
Hello there:
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Jan 19, 2010 | Kenmore 500 6952 Dryer
Heating part of Indesit ISA60v tumble drying has stopped working. Can you give me info as to where to look im a Electical-tech cheers chris
Hello there chris
Proper Voltage
81f68d1.jpg Heating Element
97ed1ca.jpg Thermal Fuse
0a798b8.jpg Thermostat
7e97613.jpg Timer motor
Jan 13, 2010 | Dryers
There is no heat to dry clothes.what do I do?
My dryer will not heat up.Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 12, 2010 | Kenmore Dryers
Kenmore dryer no heat
check the thermal fuse to see if it's open which means blown(no continuity through it). check to see if heat element is broken somewhere. And if thermal fuse is blown then you'll also have to replace the thermostat switch and the high limit thermostat switch(located close to heat element).
Apr 05, 2009 | Dryers
Dayton 1VNX2 Oil Filled Electric Radiator Heater Logo
184 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
