Question about Frigidaire GLTF2940ES Front Load Washer
Water going in washer is pouring out the bottom of the washer. Pedestal is full of water.
  • lauripat Feb 07, 2010
    There is no rip or tear in the boot that I can see or feel. I removed the top and all the hoses are attached. I turned it on to see if water was coming out of any hoses. It starts to fill, then water just pours out of the bottom. Left side as you face the washer (might just be slightly lower floor on that side). In looking down through the insides of the washer from the top, I cannot see or feel any water by reaching inside as far as my arm will go. Any other ideas?
    Thank you.
  • lauripat Feb 11, 2010
    As it turns out, there is a filter in the hose connecting to the pump. That filter was seriously clogged.. After cleaning that out, and replacing it, the washer is working fine. Thank you for your help.
  • 576 Answers
Take the two screws out from underneath the bottom panel in the front and remove the panel. You should be able to see where it is leaking. You may find that the hose leading to the pump near the front is the problem or the pump itself. Let me know if you need more help. Good luck.
Posted on Feb 11, 2010
  • 767 Answers
Well it is one of two things the hose on the drain pump came off or the detergent dispenser draw and water feed line is broken or off. You will have to fin out were the water is leaking from which side left or right if it is the right then it is the drain pump pull the bottom plate off the washing machin and use a flash light to look inside to see if the black hose to the drain pump is off or broken. If it is on the left side it is from the detergent dispenser drawer and slide that is causing the water to flow onto the floor. Pull the top off and you will be able to see the water feed slide that the water flows into the drum on to see if it is out of place or broken.
Posted on Feb 08, 2010
  • Heath Moyer Feb 08, 2010
    It has to be leaking from the hose the connects to the pump. If you take the lower panel off from the fron you should be able to see the black hose that connects to the pump it may be coming from the pump housing itself so I would check around the pump that has to be where it is leaking from.
  • 311 Answers
The first thing I would check is your rubber boot that goes around the door. Its very common for these boots to get a tear in them. When the washer is filling the water comes in from the top left hand corner of the boot. You can reach your hand up there and you should feel the plastic piece that hooks into the hole in the boot. Make sure it has not popped out of place.
To replace the boot (part# 134515300 approx $135) you have to remove the spring clamp around the front of the boot. Just take a pair of needle nose pliers and pull down on the spring. (Its located at 6oclock) Then fold the boot inwards and you will feel the rear clamp. These are sometimes a spring clamp or it will have a phillips bit on it and needs to be unscrewed to remove the clamp. You may need to remove the square bit screws at the bottom of the access panel to get better access to the clamp.
Then assemble in opposite order. When installing the new boot work around in a circle feeding it into place. Do not try to go from one side to the other its nearly impossible. This can be a very frustrating job if you have never done it before.
If there is no rip in the boot you can remove the top panel there will be 3 screws in the back. You then just push back on the top panel (towards the rear of the unit) it will slide out and off. You can then check your fill hoses for leaks from there.
Let me know how it goes. Good Luck _MJ_
Posted on Feb 07, 2010
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
The toilet isnt flushing and water is not filling into the cistern? (at the top) how do i fix this problem??
If I understand correctly, the tank that holds water is not filling up with water.
1) If this is the problem, then you need new toilet fill valve.
Or clean sediment out of existing fill valve by removing and soaking in CLR calcium rust lime.
To replace fill valve:
Look at water supply line coming into tank.
Supply line connects to fill valve.
Buy new fill valve at home center, hardware store, or walmart, or online.
There are two nuts connected to valve. Each nut has companion rubber washer
One nut & washer seal water supply line to tank.
Second nut & washer seal valve to tank.
2) If water tank is full of water, but water does not flow rapidly into bowl when you push flush lever, then your toilet is clogged with sediment.
To solve sediment problem when flush water will not flow rapidly into tank, then buy CLR calcium lime rust.
Pour CLR down into overflow tube located inside water tank.
Make a funnel by cutting off bottom of water bottle, or cut paper cup into a funnel.
Pour cup-full after cup-full of CLR into overflow tube until sediment and CLR are coming out all flush holes located under-rim on bowl.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 | Home
Water pouring out from bottom of machine leading to loss of pressure
You will need to remove the main cover and see where the leak is coming from. Could well be either the water inlet or the main pump seals .
May 20, 2010 | Karcher PSI Electric Pressure Washer
F21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Washer won't start. water pours down sewer pipe
Hi, If the water is going out the drain hose, raise the drain hose so that its highest point is as high as the top of the washer. This should take care of the issue. If the water is coming out of the bottom of the machine, tip it back against the wall and look under the washer to see if a hose has broke or came loose.
If I can assist you further, please let me know.
Vic
Jul 18, 2009 | Roper RAS8445KQ Top Load Washer
HOTPOINT AQUARIS WMA58
take out the powder box and ensure connecting pipe to drum is not blocked,hope this helps
May 12, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Front load washer poured water from bottom
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Dec 28, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Drops of water inside pedestal of washer.
Sounds like you have a leak around the door bellow somewhere, or your drain pump. The bellow is the rubber gray boot the seals around the wash tub and door. You will need to remove the bottom panel under the door to be sure. Remove the screws under the bottom edge of the panel. Once removed, the panel will drop down, then off. Inspect the washer with a load running. If the bellow leaks, a tell tale sign will be moisture showing up on the concrete counter weight in the front of the washer. Double check your drain pump and hoses as well. The pump is located directly under the wash tub in the front of the washer. The water tends to pool in the cabinet before it leaks out and drops into the pedestal drawer. If the bellow is leaking, make sure inspect it for rips and tears. You may just have a banding clamp that is loose. If the pump is leaking, make sure the clean out trap is on correctly and snug.
PS If you just purchased this washer and are experiencing problems already, this repair is covered under the one year limited warranty. Inspecting for a leak is not going to void the warranty. However, removing any major parts may. Just do an inspection to see if it is something obvious. If you suspect a part failure, get in touch with the retailer. If this was purchased from S**rs, they usually have a 30 day satisfaction guarantee. If you are not happy with the appliance, they should take it back.
Please let me know if you need further assistance.
Jun 01, 2008 | Whirlpool Washing Machines
Maytag Washer overflowwing
I had the same problem. My whole basement flooded. Inside the back (you can see it thru a small hole 1/2 way up on right) a small white hose connects to the water shut off collection area. This hose carries the water from the tub to the collection area and tells the machine to cut off for the size of load selected. Mine had come undone and so the machine could not sense it was full and the water poured all out the bottom. I simply removed the small gray panel at the bottom on the back and reached up inside to reconnect.
Jan 26, 2008 | Maytag Performa PAV2200
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
